E-fuel filter ???'s
Old Oct 18, 2018 | 08:38 AM
humphrey169's Avatar
humphrey169
Wait. Are you guys running your efuel setup through the factory lines and selector valve?
Old Oct 18, 2018 | 01:21 PM
7.3 forever's Avatar
7.3 forever
I believe some people do if they continue using both tanks. I posted list like that because I believe most people do. I am running a sump in my front tank and a small 12v pump that pumps fuel from my back to front tank off a relay. That I tapped the trigger wire into the power wires off my selector switch to kick on when I switch to my back tank.
Old Oct 22, 2018 | 09:04 AM
Jarrett Campbell's Avatar
Jarrett Campbell
My efuel system uses the stock selector valve and return lines, it only replaces the engine fuel supply on the downstream side of the selector valve.
Old Oct 22, 2018 | 09:34 AM
humphrey169
I was worried about not flowing enough through that valve so switched to the 38 gallon tank and did away with the valve.
I have a sump and 3/4 " hose to the aeromotive a1000 then 1/2" to the injection pump and 3/8" return
Old Oct 23, 2018 | 11:16 AM
Jarrett Campbell
With your setup, you're probably right in saying the stock supply stuff wouldn't have kept up. For my (near) stock stage 1 injectors, it's plenty.
Arnold Kenyon
15
Jan 27, 2021 12:50 AM
DonJuanDiego
Jun 4, 2014 10:37 PM
riverrat41
6.7L Power Stroke Diesel
Feb 16, 2013 06:03 PM
Tom D
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jun 1, 2008 07:08 PM
jtharvey
Feb 22, 2007 12:31 AM
