4.9 Starting Issues
Old Oct 14, 2018 | 12:32 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
4.9 Starting Issues
Unrelated to the starter engagement issue I've had (separate thread), I'm also experiencing a tough starting problem, especially when cold. Often a long or a couple cranks will be required to get the engine to start, and I often have to keep my foot into the accelerator a bit or it will stall. Once running, the engine seems to run fine. No error codes at this point.
So far I installed new plugs and a fuel filter with no change. I've tried a couple different PCM's, also with no change. Checked the cap and rotor - they looked good. I have spare parts, so I don't mind doing some parts-swapping diagnostics. TPS, Ignition Coil, and MAP are all easy enough to swap out, but I haven't yet.
I doubt it's the TFI or PIP, as my experience with those failing is that they are heat sensitive, and less likely to show evidence of failure when cold.
Old Oct 14, 2018 | 02:42 PM
timbersteel's Avatar
timbersteel
What is Fuel psi engine off, truck cold when you turn the key on?
Old Oct 14, 2018 | 08:15 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Haven't checked, but that's a good thing to check. You thinking fuel pump heading south? When I installed the new fuel filter a couple days ago I was surprised to find no pressure when I removed the line from the filter.
Old Oct 15, 2018 | 02:49 AM
timbersteel
If fuel psi is low, you could narrow it down to either a failing pump or leaking fuel injector.
I have encountered a similar problem with my '92. Luckily, fuel psi was fine, with key on, engine off. And it would hesitate during the hot weather, but only before starting the truck in the evening before work. 12 hours later in the morning, and it fired right up.
I swapped ICM, TFI, checked and swapped ECT and IAT sensors. I also pulled the SPOUT jumper, trying to isolate the problem.
So far my troubleshooting has me at fuel problem since I had dual tanks and neither had fresh fuel in nearly 9 months. Both tanks were completely full. I have been on vacation and haven't had time to drive it more. I was finally able to run the front tank down below a 1/4 tank and I'm just waiting to put fresh fuel in it.
EasyDawg
Jan 21, 2017 11:05 PM
1982fordf100
Nov 18, 2012 08:22 PM
kalsc
Nov 19, 2011 08:21 PM
1986fordrangerman
1997 - 2003 F150
Mar 3, 2009 03:44 PM
barca_texas
Oct 27, 2005 01:25 AM
