84 inline6 feedback conversion questions
Old Oct 14, 2018 | 12:27 PM
1984oldn’slow's Avatar
1984oldn’slow
So I recently bought an 84 F150 with the in-line 6 and a 4 speed granny transmission and it’s 4x4. The previous owner had the feedback carb completely disconnected and the connectors wiring that plugs into the distributor is altered. It was running super rich and smoking a lot of gas out of the exhaust. I got a non feed back carb on eBay and fixed all the vacuum leaks and it runs really smooth and idles great now with 20in of vacuum. My question is that I read in a lot of other threads that I need a duraspark 2 distributor and module which I have purchased just not installed and I’m 17 and still learning a lot about engine and I was wondering what difference it would make since it’s idles and runs good. Thanks- Colby
Old Oct 14, 2018 | 02:42 PM
FuzzFace2's Avatar
FuzzFace2
If you are still running the feed back dist. (TFI unit) it has no vacuum or mechanical advance.
Advance is controlled by the computer and because you are running a non-feed back carb the computer goes into "limp mode" and locks the timing.
Because it has no advance the motor will lack power and not run its best.
Dave ----
Old Oct 14, 2018 | 04:49 PM
1984oldn’slow
Dave ----
thanks, do you know how much it will effect the gas mileage with a properly tuned non feed back carb and the tfi distributor?
Old Oct 14, 2018 | 05:00 PM
ctubutis's Avatar
ctubutis
Dude... have you actually *driven* the thing on the road in its current condition?
Old Oct 14, 2018 | 05:02 PM
85e150's Avatar
85e150
I bet he has as he chose "1984oldnslow" as his forum name......
Old Oct 14, 2018 | 05:10 PM
ctubutis's Avatar
ctubutis
Yeah, that occurred to me afterwards, my comment was my original, knee-jerk reaction without knowing much about the situation.
If the timing isn't advancing, performance (acceleration) is gonna be crap. You could maybe get it up to highway speeds but you should be able to tell that something's wrong. People sometimes force that condition for a short time to pass an emissions test.
True limp-home mode won't let you get over ~30 MPH.
In any event, a non-computer-controlled ignition system is necessary to restore any sort of acceptable performance.
Old Oct 14, 2018 | 05:30 PM
85e150's Avatar
85e150
Sounds like he has a handle on the carb. When I started at Fedex we had thousands of new '84-85 E250s with the 300. No one could figure out how to keep the exhaust manifolds tight. Ditto my '85. After any long trip, I would be out trying to tighten that thing up.
EFI exhaust manifolds seem to be the answer. OP can find more info on that in the Six forum.
Good luck!
Old Oct 14, 2018 | 05:54 PM
1984oldn’slow
yeah I have, I haven’t done anything to figure out the gas mileage
1984oldn’slow
yeah, she definitely isn’t a race truck lol but it’s just a work truck
Old Oct 14, 2018 | 05:55 PM
1984oldn’slow
well I’ve got it up to 70 mph
Old Oct 14, 2018 | 05:59 PM
1984oldn’slow
Good luck!
I’ve got it up to 70mph. I just figured that the slow acceleration was the 4 speed granny transmission. It just seems to be geared reallly low. But I’m not looking for acceleration I just want tourqe and decent mpg
Old Oct 14, 2018 | 06:02 PM
1984oldn’slow
I’m just glad someone got a kick outta my username 😂lol
Old Oct 14, 2018 | 06:58 PM
Franklin2's Avatar
Franklin2
Fuel mileage and throttle response will be noticeably improved with the proper distributor. I have never owned a six, so I can't tell you actual numbers.
Old Jun 1, 2019 | 03:45 AM
mountaintruck1's Avatar
mountaintruck1
Believe it or not, my dad disconnected all the emissions and the truck ran ok for a long time. im working on either restoring it to stock feedback/emissions system or duraspark/ restomod. not sure which is better. Thats for another thread.lol
reamer
45
Jan 24, 2014 02:07 PM
mlb200180
Jan 4, 2009 11:50 PM
blackgtstang
May 17, 2006 12:46 PM
brownstraightsix
Jan 17, 2006 10:27 PM
WRC
Bronco II
Dec 2, 2003 11:37 PM
