Front end stability - has anyone else studied it?
Over the past few thousand miles I have paid attention to the front end a bit. I got a camera for other purposes but figured I could use it to watch the front end also. Ive been doing that for about 2000 miles now.
What I have found is the steering components and radius arms all work as they should - there is no rotation of the axle and there is no bounce in the rotation of the knuckles/tie rod movement that isnt cause by steering wheel input or bounce from the steering movement on bumps transferred to the steering wheel (very minimal).
The movement I do see is up/down with the springs - I would say a combination of tires and shock absorbers.
However, and on-point with the title of the thread, I have found that the stability is worse when turning left, as opposed to right, when crossing rough road on the highway. That would mean the track bar is under compression on a left turn. Conversely, the track bar would be under tension with a right turn.
If the track bar is u der compression that force is spreading the suspension apart, however slightly.
Is that spread of the suspension the cause for the decrease in stability?
Im still curious as to what I asked about the axle spread and the stability. Under that scenario the load on the springs is transferred from the springs to the track bar = lightening up the load on the springs. The load on the axle as a whole isn't really changing (like hooking up a heavy bumper pull trailer where the tongue weight pulls weight off the front), but the forces are changing when pulling a turn. The downward weight is just going different places under different turns.
The track bar mount on the axle is tight, the fitment of the mounting bolt is tight (no wollered out holes in the mount - new track bar) and the track bar ball joint on the axle was replaced. So that should pretty well be out of the question - which gets back to my point about the shocks and tires. That, for now, answers the question of the bounce I still get at times. So that is not what I am asking - how to resolve that issue, because I already have a logical direction. My question was - and a bit more information - since the issue is not on-going, and only under certain circumstances, there has to be another cause - is the load from the springs transferring to the track bar (the "spreading of the axle" affect described in my first post) the cause of the loss of stability? In other words, is that "less stable" condition the trigger point for the bounce to occur when the bounce does not occur all the time?
