Heads
Old Oct 12, 2018 | 04:06 PM
Weberman3's Avatar
Weberman3
Heads
Curious for a 95 351w. Factory head since 351, GT40 for bigger exhaust valve, or GT40P
Old Oct 12, 2018 | 04:34 PM
GoinBoarding's Avatar
GoinBoarding
Gt40p outflows the Gt40 by about 5% despite smaller exhaust valves, and the chamber design is more efficient. But, that better chamber comes at the cost of the awkward plug angle. Most LT headers can work despite that. However, for a no bs install the Gt40 will be easiest.
The combustion chamber is a little tighter in the Gt40p as well.
Old Oct 12, 2018 | 05:05 PM
Weberman3's Avatar
Weberman3
Just some 90 plugs clear alot up doesnt it?
Old Oct 12, 2018 | 06:00 PM
GoinBoarding
They can help. I only needed 1 90degree boot, on #7. The rest had plenty of clearance. A short plug could be used too. Different headers might not need that stuff at all. Where people run into real trouble is trying use shorty headers that hug the engine, like in a Mustang.
Old Oct 14, 2018 | 09:39 AM
Weberman3's Avatar
Weberman3
Do you have trouble changing spark plugs on either side?
Old Oct 14, 2018 | 10:19 AM
GoinBoarding
Seven of them are easy, but cylinder #7 is difficult. I had to modify a socket. I've heard Flotech headers fit well in that regard. I have some Chinese ss headers, they needed a lot of massaging to fit: tight to #7, hit the starter, and the flange holes were way off.
Old Oct 15, 2018 | 07:58 AM
'89F2urd's Avatar
'89F2urd
As boarding said, flowtechs and most long tube headers designed for the trucks have plenty of plug clearance with p heads, as the primaries come straight out before beginning their bend down toward the collector. With shorty headers, you'll have to get creative to install and access plugs
Old Oct 16, 2018 | 01:39 PM
Aj-'s Avatar
Aj-
When I put my gr40ps on I found that the plugs weren’t as bad as everyone made them seem. But #7 is definitely difficult but I’ve seen worse in my dads jimmy with a 4.3
1976fordguy
Feb 2, 2015 09:36 PM
fireman660r
30
Feb 20, 2009 11:17 PM
Rich95f150
Exhaust Systems
Jul 25, 2008 07:44 PM
scottjohn
Feb 26, 2003 12:42 AM
jrocco
Oct 18, 2001 10:15 AM
