Fuel filter time
Old Oct 11, 2018 | 05:57 PM
jimzpsd's Avatar
jimzpsd
Fuel filter time
First time on this, .......so do I simply drain the water separator valve until the fuel flow stops on its own, and then remove element? I've heard the horror stories of how people got the diesel bath and how the fuel never stopped draining. Just looking for the latest tips before I dive in, thanks.
Old Oct 11, 2018 | 07:48 PM
TXKR's Avatar
TXKR
There are two elements, one at the tank and one up front in the engine bay. These cover it pretty well:
https://www.youtube.com/watch?v=NJGaoNH1N-E
https://www.youtube.com/watch?v=2fseeSLAAP4
Old Oct 11, 2018 | 08:03 PM
mhoefer's Avatar
mhoefer
For the first time, get your tank below a 1/4before you drain the water separator, then the lower filter, then the upper filter. Sometimes the check valve just keeps draining, and while it’s not supposed to, but better than a mess.
Old Oct 11, 2018 | 08:55 PM
GrantGunderson's Avatar
GrantGunderson
Anyone have the part numbers for these? Trying to find on amazon or elsewhere as only the stealership has them locally. Thanks!
Old Oct 11, 2018 | 09:08 PM
TXKR's Avatar
TXKR
Easy Google/Amazon search, PN FD4625
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=FD4625+ https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=FD4625+
or:
https://www.ebay.com/itm/New-OEM-Mot...-/263232631317
Old Oct 11, 2018 | 09:39 PM
jimzpsd's Avatar
jimzpsd
I know the procedure, just not clear as to why I should have less than a quarter of a tank. In other words if I went to the dealer for this with a full tank, they would send me away and tell me to come back after 3/4 of the tank is consumed?
Old Oct 11, 2018 | 10:01 PM
mhoefer's Avatar
mhoefer
If you went to the dealer and it kept pissing diesel they would take their time, drain a bunch of and eventually get the filter changed while it’s still draining probably. Just a precaution so you don’t fill 22 milk jugs full of diesel. I take mine in, it has a service package, and I take it in with less than a 1/4 tank. Force of habit from doing the 2005. Always got a soaked arm, shirt and more even with just a quarter tank. Some guys have said no problem, not necessary, some have done the 1/4tank. I am not taking my truck for service and leaving it with 1200 km of range and a full tank.
Old Oct 12, 2018 | 07:42 AM
jimzpsd's Avatar
jimzpsd
I get what your saying, but any significant amount of fuel wasted from the dealership should be replaced at their expense. But I still do not understand the 1/4 tank thing prior to doing the job.
I found this video, seems real easy.
Old Oct 12, 2018 | 07:58 AM
troverman's Avatar
troverman
Fuel filter job is pretty easy. I did mine at 2k miles out of necessity when my 2017 gelled up last winter. My truck had a full tank.
Old Oct 12, 2018 | 08:36 AM
jimzpsd's Avatar
jimzpsd
I realize how easy it is, my concern is the 1/4 tank......why? (And if there is some kind of check valve that is not stopping the fuel flow, its a warranty issue to get fixed by the dealer vs waiting until I get down to a 1/4 tank.)
Old Oct 12, 2018 | 08:52 AM
k7lvo's Avatar
k7lvo
^^^^^^Yes!
ive change the filters on my 17 3 times. The only time I had an issue was when the tank was almost full. After about a gallon had drained, I shut the valve and waited until I had driven enough to lower the fuel to ~1/4 tank, then tried again, without incident.
I dont know why it works that way, but, when the answer is so simple, why fight success? (Especially since I’m out of warranty...)
Old Oct 12, 2018 | 08:57 AM
Busa 1 Dave's Avatar
Busa 1 Dave
Nothing wrong just a quirk of these trucks. Just follow the advice you have gotten and you will be fine.
Old Oct 12, 2018 | 09:23 AM
HRTKD's Avatar
HRTKD
Is it safe to say that if you open the drain valve, drain off a quart of so of fuel and it stops, that when the fuel filter compartment is opened that there won't be a flood of additional fuel?
Old Oct 12, 2018 | 09:39 AM
troverman's Avatar
troverman
The 1/4 tank advice is to prevent a siphoning effect from draining the tank if your truck is missing or has a malfunctioning check valve.
Old Oct 12, 2018 | 09:51 AM
jimzpsd's Avatar
jimzpsd
Just finished the job (with 3/4 full tank), took 20 minutes. Drained out apprx. 3 qts. of fuel then it stopped on its own (perhaps I have a functioning check valve).
