Sponsored by: Real Truck
Power windows stopped working
Old Oct 11, 2018 | 10:31 AM
ScotF150's Avatar
ScotF150
Power windows and radio are dead. Fuses good, no power to the fuse. I was putzin with the distribution block under the hood while troubleshooting the 7 pin trailer connector but only removed fuses to check for voltage. Any ideas on where to start.
​​​​​​​Thx, Scott
Old Oct 11, 2018 | 04:40 PM
ScotF150's Avatar
ScotF150
Had time to do a search and it appears the instrument cluster is the issue.
Old Oct 11, 2018 | 04:49 PM
Colorado350's Avatar
Colorado350
What year and model truck? When you were “putzin” did you disconnect the batteries first? Did you pull any fuses…and forget to put them back?
Old Oct 11, 2018 | 06:56 PM
ScotF150's Avatar
ScotF150
2006 F350 CC 6.0. The only thing I did was pull the fuses for the trailer circuits and check them. No need to disconnect the batteries to check fuses but it may reset my issue.
Scott
Old Oct 11, 2018 | 08:24 PM
Colorado350
Scott, Since you didn’t disconnect batteries, my guess is MAYBE a fuse blew somewhere. If it were me I grab a test light and check them all with the key off and in the run position. Hopefully it’s something simple. :drinks:
Old Oct 11, 2018 | 09:48 PM
ScotF150's Avatar
ScotF150
I did a quick check on the fuses but I don't have power to the fuses. I'm off this weekend and I'll troubleshoot it and post up what I find.
Thanks,
Scott
Old Oct 13, 2018 | 07:44 PM
ScotF150's Avatar
ScotF150
Did some troubleshooting today and found the circuits involved are on the delayed accessory relay. The relay isn't getting power to actuate. I did swap relays. I'm leaning toward a defective instrument cluster. I'll call the repair service on Monday.
Scott
grif95
May 27, 2016 06:26 AM
sudsmcduff
All Things Towing
13
Dec 24, 2013 11:43 PM
dmanshane
Nov 11, 2011 06:06 PM
rb8484
Aug 18, 2011 11:01 PM
mbarton
Jun 15, 2011 11:04 AM
