Help!
Old Oct 11, 2018 | 01:45 AM
Medic_ISH's Avatar
Medic_ISH
Help!
Need help figuring out whats going on with my baby. Its a 2000 Excursion 4x4 lifted beauty. Recently had issues with with overdrive staying on. When I turned it off the vehicle would have trouble shifting. Then my battery would suddenly die. Alternator was good. Today I put in a brand new battery and when I went to start it there was no crank, 2 fuses under dash were making clicking sound. I moved the battery terminals around and then the it started on the second try. Still clicking under dash, security light on, and windows moving up and down on their own. Im a do it your self kinda guy but not sure how to tackle this problem. Where do I start, any suggestions or help is greatly appreciated.
Old Oct 11, 2018 | 03:10 AM
seville009's Avatar
seville009
May be bad battery cables, especially if it works after you moved them around
Old Oct 11, 2018 | 03:46 AM
Medic_ISH's Avatar
Medic_ISH
Bad cables would cause the windows to move up and down on their own?
Old Oct 11, 2018 | 04:34 AM
Jesse Walter's Avatar
Jesse Walter
Not sure if your year is the same, but my 2004 has a ground strap from the frame to the body under the passenger door. Mine was broken and caused all kinds of crazy issues.
Old Oct 11, 2018 | 05:39 AM
01__Excursion's Avatar
01__Excursion
The dreaded leaking windshield, and wet GEM module..??
Old Oct 11, 2018 | 06:01 AM
DavenTn's Avatar
DavenTn
There is no magic fix, remedy or repair for these type of problems. Good deliberate troubleshooting skills are necessary, along with patience, wiring diagrams/prints and a good multimeter.
Old Oct 11, 2018 | 06:59 AM
wpnaes's Avatar
wpnaes
Welcome to FTE, start with the first 2 below, then see if you want to tackle the 3rd post if applicable.
https://www.ford-trucks.com/forums/1...l#post12209418
https://www.ford-trucks.com/forums/1...l#post16884895
https://www.ford-trucks.com/forums/1...l#post16883830
Old Oct 11, 2018 | 09:14 AM
PrescottIce's Avatar
PrescottIce
Yep - bad grounds or a wet/corroded GEM can cause battery drain and random operation/no operation of seemingly unassociated components. Ground issues can be a chore to find, and the GEM problems, if present, look painstaking to fix (I have the "issue", but haven't tackled it yet). Looks like you have a beauty there, it will be worth the effort though. As stated above, methodical troubleshooting as in the Workshop Manual will get you there.
My guess is the clicking is the security module activated from losing power several times - the clicking is the relay to the horn, lights, or both (they may not be connected to any output, but the relays will still cycle). It should reset after unlocking the vehicle with the remote, but mine has done some wonky stuff in the past where it keeps it in "theft" mode regardless of what I do. And it's always after multiple disconnects/reconnects of the batteries.
Old Oct 11, 2018 | 09:24 AM
pirate4x4_camo's Avatar
pirate4x4_camo
^ This
I would not not attempt it without the factory service manuals and wiring diagram. You can find the sets on eBay, well worth the couple hundred bucks.
VTENX
Dec 10, 2022 07:03 PM
Jose Miranda
Nov 24, 2018 12:39 PM
BayouMark48
1997 - 2003 F150
Mar 31, 2015 09:18 PM
68bluebeast
16
Jun 9, 2012 12:14 AM
hajduk
1997 - 2003 F150
Mar 19, 2011 12:54 PM
