6.8 V10 Twin turbo build begins
#31
Cold side pipes are back from powder coat and the bottom end and heads are ready for assembly!
Here you can see the offset and get an idea of how the crank appears weaker due to the overall smaller size of the pin thickness.
Another shot of the split pin crank after we balanced it .I kept the rotating assembly light enough to only be off 20 grams.
Installing mahle pistons on the Shelby rods.I use Manly pistons almost exclusively in the shop for big hp builds, but for this build we chose to use the mahle due to thier weight and small ring package in a shelf piston.
Setting ring end gap prior to piston installation.
Installing the pistons/rods
#33
#34
The new assembly i used isnt really that much heavier in grand scheme of things. I used sintered forge rods, which arent much different than the powdered rods, about 40 Grams heavier. The pistons were practically a wash, the major weight difference was the pin. The better pins to hold up were about 60 grams heavier per.............. I am just fine with the additional weight, especially with this low rpm motor. I dont see it being a problem.
#35
Time to go back in!
Heads ready to install after valve job, some bowl work, a deck and some pac springs to handle the boost!
Here you can see the small modifications I made on the Chambers.
We used a complete Mahle gasket kit for this motor and I was pretty happy with it. Nice gaskets for head and exhaust as well.
Balance shaft timing
Here you can see how I split my oil feeds up for each turbo and plumbed in the stock sending unit. The driver side turbo drain is welded in the pan under the oil cooler adapter and the pass side drain is under the damper on the front of the pan.
Finally! Forged 6.8 ready for a home!
#39
#40
Nice!
Where did you put the BOV, and MAF.
How dI'd you deal with boost pressure to vacuum system and brake booster?
Does fpr "see" boost ?
How did you address boost pressure to drivers side valve cover via the breather hose?
Where did you tap vacuum / boost to run wastegated? I have noticed a 3 to 4 psi difference in boost between upper intake and the runners just before the valves in intake manifold. Probably due to restriction of upper plenum to lower intake connection.
What is the size and manufacture of the turbos?
Inducer and exducer sizes, and turbine AR? Visually the turbine housing looks rather large to run the smaller inducer. Looks like it will take some rpm to push up boost.
#41
#42
Nice!
Where did you put the BOV, and MAF. BoV and maf are in intake pipe, Maf is near valve cover but on bottom side so it's not an eye sore, bov is on ds/ intake pipe as well, coming out intercooler, look at pics you can see it.
Brake booster has a check valve, for the other stuff I used a check valve off a lighting/cobra, VW Jetta stuff is available on eBay reasonable as well .
Does fpr "see" boost ? Absolutely, for 1:1 rise
How did you address boost pressure to drivers side valve cover via the breather hose? I **** can all that. I have both valve covers going to a puke tank and then I have one of the turbos pulling a bit of vacuum on the puke tank(filtered of course)
I referenced gates from the compressor, so I tapped the compressor housing for a fitting and sent that directly to gates, you want gates to see boost only, the bov needs boost and vacuum to operate properly.
I'm seeing boost as low as 1400 rpm. It's on the spring at 1900.
Thanks! It was a fun build. Still quite a bit to do to finalize it .
#43
#45
