6.8 V10 Twin turbo build begins - Ford Truck Enthusiasts Forums
Old 10-10-2018, 06:11 PM
qcksnake
qcksnake is offline
qcksnake is gaining momentum as a positive member of FTE.
Got started on mock up of turbo kit. Managed to get pretty lucky and the stock manifolds will flip fairly easy, i had to massage the ac lines on pass side a bit (down) and on driver side the power steering reservoir hose needs to be zip tied down out of the way, so pretty easy.
Using a stock 6.0 intercooler, had to move my trans cooler to pass side to facilitate, otherwise its just drop in and bolt it up.
Managed to hack up the stock v10 midpipe and use it for the hotside, no need to use expensive race car parts here if you dont have to.
Waiting on gates to show up and then well get started on downpipes.
engine/trans will come out when i get done with this mock up and this should give me a change to powdercoat the cold side pipes and wrap the downpipes/and hotside where needed.
Im working on this in between customers sutff so its gona be a slow go.
Passenger side turbo mock up
Driver side turbo
Old 10-10-2018, 06:18 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Great start!
Old 10-10-2018, 06:20 PM
qcksnake
qcksnake is offline
here is the intercooler and a shot of the little garretts i had
Old 10-10-2018, 10:06 PM
PrescottIce's Avatar
PrescottIce
PrescottIce is online now
PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.
I've never even seen a V-10 engine bay in real life, but that looks like a fuuuuuuun project!!! Lots more room when you don't need two batteries, I guess.
Old 10-10-2018, 10:37 PM
EXSwap's Avatar
EXSwap
EXSwap is offline
EXSwap is a name known to allEXSwap is a name known to allEXSwap is a name known to allEXSwap is a name known to allEXSwap is a name known to allEXSwap is a name known to all
Subscribing....super cool!
Old 10-11-2018, 07:57 AM
brentmitchell1985
brentmitchell1985 is offline
brentmitchell1985 is starting off with a positive reputation.
internals?
What are you doing with the internals?
Old 10-11-2018, 09:18 AM
96firephoenix
96firephoenix is offline
96firephoenix has a great reputation on FTE.96firephoenix has a great reputation on FTE.96firephoenix has a great reputation on FTE.96firephoenix has a great reputation on FTE.96firephoenix has a great reputation on FTE.
probably shredding them.
Old 10-11-2018, 10:59 AM
qcksnake
qcksnake is offline
I used a E-350 Van battery box i scored off ebay and put battery on pass side frame rail under pass seat area, ill get pics of that later.
I have some 14 shelby rods and some forged pistons, Pac springs for heads etc. Prob do a little bowl work to heads, but not much since i elected to use stock manifolds. With the low RPM setup in this truck i dont see any reason for H beam rods, but well find out i gues. I figure if 8 holes can make 100HP a hole on those rods then 10 holes shouldnt have a relibility problem with making 60-75 HP each hole.
Old 10-13-2018, 07:06 PM
Immortal_Ben's Avatar
Immortal_Ben
Immortal_Ben is offline
Immortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud of
Ok in all my years here this is only the third thread I have subbed. Mad reps sent! I am super excited to follow this!
Old 10-13-2018, 09:59 PM
qcksnake
qcksnake is offline
Managed to get started on one downpipe and almost finished the cold side from intercooler to the throttle body. I'm using a slot style meter from 07 mustang in a 3.5" tube. For the cold side I just grabbed scrap pieces I had laying around, wrinkle black Powdercoat will make it look better
Old 10-15-2018, 03:29 PM
wizkid00104's Avatar
wizkid00104
wizkid00104 is offline
wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.
Subscribing! Can't wait to see how it turns out.
Old 10-18-2018, 09:17 PM
qcksnake
qcksnake is offline
Made some small progress, down pipes and charge pipes are almost done, next step is to build the exhaust. Dual 3 inch is gonna be tight by the axles and through trans cross member
Driver side down pipe from bottom
Driver side down pipe and intake charge pipe
Passenger side down pipe and gate
Pass side down pipe from bottom
Old 10-19-2018, 10:56 AM
Downsized2X's Avatar
Downsized2X
Downsized2X is offline
Diesel User
Downsized2X is starting off with a positive reputation.
Super cool! How much added HP are you expecting out of it?
Old 10-19-2018, 11:34 AM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
All of it
Old 10-19-2018, 09:01 PM
qcksnake
qcksnake is offline
Based off the baseline numbers I'm gonna guess she goes 460-500 rwhp and around 650-700 rwtq
Plan to start at 14 psi so usually get double or more on n/a numbers it was 240/390 with a tune so we'll see
Originally Posted by Apocalypse View Post
All of it
Yeah hopefully we can keep it alive and make some decent power
Finished driver side gate dump
Driver side crossover pipe
Passenger side down pipe was by far most challenging. I also needed some short 45s on driver side and ended up reusing pieces of original y pipe so I pretty much used all of it except the little 2\" neck down pipe
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
