Decode Door Tag Please
Old Oct 10, 2018 | 04:34 PM
1965GTFB's Avatar
1965GTFB
Old Oct 10, 2018 | 08:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Decode Door Tag (Warranty Plate) Please...
Originally Posted by 1965GTFB
Where is it?
Edit: Never mind, found it in the 1957/60 forum.
Old Oct 10, 2018 | 10:15 PM
1965GTFB's Avatar
1965GTFB
Hi Bill,
That's a different truck in the 57-60 forum.
This truck with the tag above(on the yellow truck) is for a different truck then the one you decoded in the 57-60 forum. A 1966 I'm pretty sure.
It is owned by a friend and used to be the local fire chief's truck. Likely the color code is Ragoon Red.
Old Oct 10, 2018 | 10:18 PM
NumberDummy
Hi Bill,
This truck with the tag above (on the yellow truck) is for a different truck then the one you decoded in the 57-60 forum. A 1966 I'm pretty sure.
It is owned by a friend and used to be the local fire chief's truck. Likely the color code is Rangoon Red.
OK, but where is the tag for this truck? It's not in post #1.
Old Oct 10, 2018 | 10:22 PM
1965GTFB's Avatar
1965GTFB
Is the pic not showing up? I see it on my post.
I can key in the #s if the pic is not showing.
Old Oct 10, 2018 | 10:38 PM
1965GTFB's Avatar
1965GTFB
Tag #s are:
F25YR862446
WB: 129
Color: J
Model: F253
Body: 481
Trans: C
Axle: 24
GVW: 06000
HP: 172
RPM: 4000
DSO: 72
Old Oct 10, 2018 | 11:44 PM
RangerMercMan's Avatar
RangerMercMan
1965GTFB: Your pic in post #1 did not show up. Your decipher from post #6 is as follows the best I can:
F25 = F250
Y = 352 V8
R = San Jose assembly plant
862446 = late 1966 (sorry I do not have my book handy)
Colour = Rangoon Red
Body = light beige if I recall... standard cab
Trans C = 3.03 3 on the tree which seems odd for a 3/4 ton even though you are light
Axle = I do not know due to lack of book right now
GVW = 6000 kinda light and hence the model F253
DSO = northern California off the lot
Old Oct 11, 2018 | 10:58 AM
NumberDummy
F25YR862446 / WB: 129 / Color: J / Model: F253 / Body: 481 / Trans: C / Axle: 24 / Max GVW lbs: 06000 / Cert Net HP: 172 / RPM: 4000 / DSO: 72
F25 = F250 2WD
Y = 352 2V
R = San Jose CA Assembly Plant.
862446 = 1966.
129" Wheelbase.
J = Rangoon Red.
F253 = F250 2WD, 6,000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
C = Ford type 3.03 3 Speed Manual all Synchromesh Transmission.
24 = Spicer/Dana 60 Rear Axle / 4.10-1 / 5,200 lbs. Axle Capacity.
6,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
allentown09
Oct 24, 2018 05:06 PM
DDDDDMorgan
Aug 31, 2016 11:14 AM
abe
Mar 26, 2016 09:05 PM
Festus Hagen
Apr 14, 2010 11:07 AM
ampslw
Jan 14, 2010 12:05 PM
