TDC
Old Oct 11, 2018 | 03:58 PM
charliemccraney's Avatar
charliemccraney
You also cannot rely on the timing marks unless you are certain that the damper is in good condition. The damping mass tends to slip over time. Since the marks are on that mass, it can no longer indicate correct timing once that happens. If the history of the damper is unknown, then it is time to replace it.
It's also possible to have the distributor 1 tooth off so that the intake prevents you from achieving the desired timing; the vacuum can hits the intake. In that case, pull it, rotate one tooth, drop back in and all should be well..
Old Oct 11, 2018 | 06:21 PM
okie trucker's Avatar
okie trucker
well it has no timing indicater so don't have to worry bout that. Went ahead today and pulled distributor and got engine to TDC. Hopefully tomorrow will be a good day. Thanks all you guys.
Old Oct 11, 2018 | 06:24 PM
RangerMercMan's Avatar
RangerMercMan
Sorry to ruin tomorrow for you but you need to start worrying about those missing timing marks if you desire good reliable, efficient and powerful daily driving!
Old Oct 11, 2018 | 07:14 PM
okie trucker
haven't been able to find a pointer and no lines on damper. Now what
Old Oct 11, 2018 | 07:37 PM
charliemccraney
Pointers are usually on eBay. Have your damper rebuilt or order a new one from Powerbond in Australia. The Powerbond part number is PB1199N. There are also some advertised to be new and made in Mexico on eBay. You don't want used. Even NOS may be no good because time takes it's toll and the rubber stuff between the mass and hub could be bad.
I agree, it's never going to be right until you get those things straight.
Old Oct 11, 2018 | 07:44 PM
okie trucker
thanks Charlie, looks like research is up next
Old Oct 11, 2018 | 08:25 PM
RangerMercMan
Charlie answered that one for me. Maybe TA455HO or Numberdummy will chime in on a damper closer to home than Australia. No offense to the Aussies they are deep into speed and performance and know their stuff, they are just too far away.
Old Oct 11, 2018 | 09:32 PM
charliemccraney
I just googled the Powerbond part number. You can get it at Summit. Also branded as Dayco from other vendors. So plenty of options for it here in the US. New is the best way to go.
Old Oct 12, 2018 | 08:38 AM
okie trucker
Again, I thank you.. Thanks for the legwork.
Old Nov 29, 2018 | 10:52 PM
okie trucker
TDC
OK. Pretty sure distributor is in correct position. Got a timing pointer & put it on. The timing marks on the damper I did find. They have slipped to the top right side of damper at TDC. I am attaching a drawing of the timing marks. I couldn't get my computer to rotate the drawing, sorry. I'm wondering if I can attach this drawing on the damper, which one of the first two lines would line up with pointer at TDC.
Bottom line should actually be on left side
Old Nov 29, 2018 | 11:10 PM
RangerMercMan
You could maybe try aluminum tape and draw it on that. I will have to leave the alignment of the marks to someone else as I only have the specs for a 352 in my manual. I am glad you are making progress.
Old Nov 30, 2018 | 04:44 AM
Crop Duster's Avatar
Crop Duster
I'm no "Y" block expert. The last Ford I owned with a "Y" block was a 56 Crown Vic and that was in 1965. My motors manual is only for cars but it shows two different timing pointers for "Y" blocks. Some had the timing marks on the damper with the pointer as a zero reference. Some had the timing marks on the pointer and zero reference on the pulley. Is your engine original to that truck? Have you looked for any casting dates on the block?
If you just want to get a zero reference to work off of and get it running here is the easiest way.
Buy or make a piston stop.
Pull all the plugs to make it easy to turn.
Bring it to TDC #1 cyl.
Turn in opposite direction of normal rotation 1/2 turn and install the piston stop in #1 cyl.
Turn the engine in the direction of normal rotation until you touch the stop and put a mark on the damper at the pointer.
Now turn the engine in the other direction until you touch the stop and put a mark on the damper at the pointer.
Remove the piston stop.
Top dead center is exactly half way between those marks.
But if you have the correct damper and pointer and if that damper has really slipped, you are probably wasting your time because one little stumble or back fire and it's going to move again and all your effort will have been for nothing.
Old Nov 30, 2018 | 06:33 AM
  #28
Tedster9's Avatar
Tedster9
Drove my "new" Y for quite a while with a slipped damper, it sure made setting the ignition timing a headscratcher because I didn't know that could happen.
Thing is, in theory at least a defective damper can cause the crankshaft to crack or even break. It can't do its job when the rubber dry rots or fails. Loss of timing marks is just a fringe benefit. There is a specific RPM range where a crankshaft reaches resonance and (more likely) what can happen is the heavy steel damper mass will unass itself and launch through the radiator or hood or golly knows where. May contribute to oil leaks too, it's just got to pound the hell out of bearings &c I'd think.
For now just set the initial timing to just short of maximum steady manifold vacuum on a gauge and it should run well till you can get a new damper installed. Ys like lots of advance over stock settings.
Old Nov 30, 2018 | 07:36 AM
  #29
okie trucker
Thank you RangerMercman, aluminum tape:
Old Nov 30, 2018 | 07:42 AM
  #30
okie trucker
Tester, how do I get it to just short of maximum, without timing marks
