TDC
Old Oct 10, 2018 | 09:24 AM
okie trucker's Avatar
okie trucker
TDC
If I turn crank to find TDC, do I need the distributer pulled out before. 292ci Y block 1963
Old Oct 10, 2018 | 10:22 AM
Baker66FordF100's Avatar
Baker66FordF100
4wd High
TDC
You shouldn't have to take it out just make sure the distributor isn't getting any electricity to it so it doesn't fire up.
Old Oct 10, 2018 | 12:36 PM
okie trucker
Negative cable is unhooked thanks. Just remember to move rotor to no. 1 plug, correct ?
Old Oct 10, 2018 | 01:04 PM
Crop Duster's Avatar
Crop Duster
What exactly are you trying to do? Have you had the distributor out?
Old Oct 10, 2018 | 03:05 PM
okie trucker
helper pulled it out without marking it. It's back in but doesn't run well. Trying to TDC so I can reset distributor.
Old Oct 10, 2018 | 04:34 PM
RangerMercMan's Avatar
RangerMercMan
When you think you have TDC on the number one plug make sure you are on the compression stroke and not the exhaust. You can confirm this by removing the spark plugs and putting your thumb on the number one hole while hand rotating the motor. When you feel air pressure you found number one TDC for timing. Then you remove the cap and look to see where the rotor is pointing. Make sure the wire it points to goes to number one. Repeat six more times and number eight is last one to figure out.
Old Oct 10, 2018 | 06:05 PM
okie trucker
Repeat what? exactly? 6 times ? you tryin to pull my leg ?lol
Old Oct 10, 2018 | 06:14 PM
okie trucker
Old Oct 10, 2018 | 06:16 PM
okie trucker
Also when I pulled #1 plug it had oil on the threads. Is that ok? or a problem ?
Old Oct 10, 2018 | 06:54 PM
User 71024's Avatar
User 71024
oil on the threads would be from the outside, probably valve cover.
Old Oct 10, 2018 | 08:07 PM
okie trucker
thanks EricJ
Old Oct 10, 2018 | 09:21 PM
RangerMercMan
Not trying to pull your leg. Once you have done the number one cylinder do another cylinder with your thumb on the hole until you feel air pressure and then make the rotor align with the wire going to that cylinder. If you do it to all of the holes you are 100% gaurenteed to have the correct firing order. You only have to thumb 7 holes and the last one #8 only has one place left to go. In terms of running rough if your advance (in terms of rotating the distributor housing while it is in the block) if you are popping or backfiring throgh the carb you are early. If it is through the exhaust you are late. If you are getting both you are out 180 degrees and need to remove the distributor and put the correct number one at TDC. Or you could do the thumb air pressure trick to confirm the correct firing order.
Old Oct 10, 2018 | 11:04 PM
okie trucker
hahaha thanks man. You know those computer books for dummy's ? I need truck books for people who are dummer than dummy's
Old Oct 11, 2018 | 03:50 AM
Crop Duster
Timing
If it will start at all it can't be that far off. What is the timing light telling you. Sounds like you may have some wires crossed.
Old Oct 11, 2018 | 07:21 AM
okie trucker
Well heck, now why didn't I think of that. Thank you.
