What part number is the green steeringwheel. So it might make it easier to find. What part number is the green dashpad and part number for green armrests and green door panels.this truck has a dark green steering column.
Reason: Dark green steeringwheel
What part number is the green steering wheel? So it might make it easier to find. What part number is the green dash pad and part number for green armrests and green door panels?
D1TZ-3600-D .. Green Two Spoke Steering Wheel / 1971/72 F100/350 / Obsolete
At least ihave part numbers now at least I have a clue to maybe find these parts any suggestions on how to replace these parts.and make it look reasonable. It doesn't have to be perfect.thank you
Reason: Any suggestions to replace parts
In your Reply window, select the Image icon (circled in red above) then in the next window that pops up, click the Browse Your Device button located in the center of the window. Then you must navigate to where your pictures are stored and select the pictures. Do that for each picture.
Once you have all the pictures you need then click the Upload button located in the upper right corner of the window.
The darker green bottom paint is a repaint job, as it is chipped and has a lot of overspray on the front fender edge. The O paint code is the original complete color. A previous owner repainted it.
