72 twotone green camper special with green steeringwheel and jade green interior wha
#46
Not original owner
I'm not the original owner I bought this truck fo 1000.00 I'm going to do a poor mans restore If I can find a green dashpad with the right part number not a fake number. Also if I can find a green steeringwheel. With a real part number. .also if I can find the right seat color dye it looks like the same color as the Interior metal color code o which is the same as exterior top color code o.bottom color code y chealsea green. but if I can't find the green Interior parts this truck is not worth Making the effort. this truck was finished being on August 31 which should mean it is a 71 but the vin tag says September 1971 which makes it a 72.so know I don't know what year to buy parts for .the marti report says august 31.the seat has a darkgreen vinyl outer section the center part of the seat looks like seapine.code o the Interior code is f4. Vin code f25hrm60707.
#47
No "VIN tags" on trucks/Bronco's/Econolines until 1980. It's located on the left corner of the dash, visible thru the windshield. Only has the VIN stamped on it.
1970/79: Safety Standard Certification Label glued to the B pillar (door post) below the striker plate. Has the Production Date, misc. GVW's and the VIN printed on it.
A truck assembled 9/71 is a 1972
F4: F = Light Green & Medium Green VINYL - Sport Custom body style 81B / 4 = Styleside Pickup.
F25 = F250 2WD / H = 390 2V / R = San Jose CA Assembly Plant / M60707 = 1972 (1972 serial number range: M40,001-Q00,000).
#48
Viny seat
The outer part of the seat is vinyl the center of the seat is cloth .not vinyl this is a 7500 gvw with heavyduty towing sport custom camper special. Super cooling. 100 amp alternator. With 14 volt voltage regulator .the larger voltage regulator came from my 70 f350 motorhome so did the alternater .
#50
VIN decoded in post #47.
Type all the codes stamped on the Warranty Plate, riveted to the left door face below the latch.
2nd line: WB / COLOR / MODEL / BODY / TRANS / AXLE
3rd line: MAX GVW LBS / CERT NET HP / RPM / DSO
#51
Door tag
F25hrm60707 131 wb color code o body f252 so interior f4 trans g axle 38 gvw 07500 165 hp rpm4000.the registration says year 1972 make ford first registered 9 72.so is this a 71 or a 72 it has a 72 grill.arizona mvd verified the info this truck came from cali if this truck is a 71 then why did cali not catch the error.
#52
H = 390 2V
R = San Jose CA Assembly Plant.
M60607 = 1972.
131" Wheelbase.
O = Medium Green Metallic.
F252 = F250 2WD, 7500 lbs. GVWR
F4: F = Light Green & Medium Green Vinyl - Sport Custom model 81B / 4 = Styleside Pickup.
G = C6 Automatic Transmission.
38 = Dana 60 Rear Axle / 3.73-1 / 5,200 lbs. Rear Axle Capacity.
7,500 lbs. Gross Vehicle Weight Rating.
165 net HP @ 4,000 RPM
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
It's a 1972, I told you that before and gave you the following info before (post #47):
The production date is 9/71 and the serial number, the last 6 digits of the VIN is: M60607. 1972 serial number range: M40,001-Q00,000.
Your truck is 46+ years old and has had multiple owners, so who knows what may have been changed, altered, modified and etc.
#53
Truck is twotone
Color code o is the top color bottom color looks like chealsea green color code y.why doest the door tag say the bottom color the door panels are the same as the bottom color the outer section of the seat is the same as the bottom exterior color so is the dash pad and the steering wheel.the dso is 71 I looked at the color code o for 72 it also says color code o is seaplne .for fordtruck
#54
DSO 71 edited into post #52.
Does the Marti Report list the original selling dealer?
#55
#56
#57
#59
Fey doesn't make a bumper that looks like my rear bumper.dennis carpenter makes on that looks like it. So now it looks like some idiot ruined this camper special. And ruined any restoreable value.now it's worth 0 dollars.please help me post pictures so someone can verify that this
#60
Ford never offered a step bumper that could be slid.
I was a Ford parts guy for 35 years, owned 10 Ford F series pickups from 1965 thru 2015 (9 purchased new), have all the parts catalogs from 1928 thru 2001, so I know what the hell I'm taking about.
