Tranny Advice
I'm at the point where I'd be ready to pull the trigger by the end of this month, but I'm starting to question whether it would just be better to wait until she blows and put in an HD4R100 ...
It only has 106k on the odometer, had fluids changed by dealer at 75k (previous owner, have record), but has had the "noisy converter" going back at least 15k mi before that according to him ... so figure 45-50k on the TC since it started...I've had it since 80k...no problems shifts firm, holds well towing...it's only ever been used for recreational towing (RV) by both the PO and myself.
My goal/thinking would be to eliminate the noisy converter, and beef it up / increase the longevity with the upgrades...also help it hold up to a little higher HP when I get around to adding a hydra/tunes and who know's what else once you head down that rabbit hole...
Does anybody have experience with these noisy converters? If its been this long...am i already on borrowed time? I don't want to throw $2k at it, and then have the tranny blow in a year anyway and have to do the whole thing again...but at the same time, if I can spend 2k instead of 4k and get another 5+ years out of it...well then that is $2k more I can spend on other goodies, vacations, etc
Sorry for rambling, just looking for some opinions!
Thanks!
I had my transmission rebuilt, triple disc TC, Tugger HD-2 shift kit it came to $3900 with unlimited mile warranty. It has worked flawlessly since the rebuild.
If you've been shaking the paint can for 15 k it is time to look at a rebuild. My 99 did the same thing and I drove it until it crapped out at 8000 miles after the noise started.
Depends on how deep your wallet is. I had my original rebuilt with the tug kit and a new converter and that was 100,700 miles ago. I do maintain the trans and thus far no issues.
My truck had roughly 100k when done.
It did require a full flush of the entire system and since your throwing away your cooler for a 6.0 I would recommend not only driving it locally but get it scheduled asap. Fact is, they are a great trans after the upgraded kit and converter.
I tow a 29 fth wheel and a 10000 pd boat. (Not together unless beer is involved) but haven't had a problem since.
Denny (by the way, my out the door was 1700 bucks. No regrets.
The rattle you hear is the TC coming unglued and circulating thru the system. It stops at the filter but like blood, it's at the bottom of the heart. JS
I had it checked by a local (to the PO) diesel specialty shop before I bought it. In addition to a test drive, he drained the fluid in the pan, and inspected it and told me everything looked perfect...that was about 20k mi ago, and about 25k mi after the PO said the rattle had started. He told me the issue was very common on 99’s and more of a nuisance than anything else....he told me to be aware of drastic changes to the noise as that was when it needed to be replaced.
My experiences are pretty much in line with what he told me with my only complaint about it being the noise...
so are you saying a rebuild is imminent and unavoidable in the immediate future?
I hadnt heard much much about the Tugger kit...I’ve been looking at either a JW or BTS valve body swap...would you be suggesting the tugger in lieu of one of those options? Can anyone who has a BTS or JW valve body installed chime in to compare?
as to your current trans, have you tested the line pressure ? Specs are in the factory service manual but I’m sure you can also google it. If you are going to add a tugger valve body you may as well through in a set of Red Eagle clutches while you have the trans out, a new pump isn’t that much more $$ since you are already in deep.
Sounds like your shaking a rattle bomb next to a brick building...........TC's imploding. Only you get a french fry order instead of a Burgrer because they can't hear you. Yep, it's on the horizon.
Denny (just reb w tugger and torque and drive away.)
I apologize for myself and the crew! It's great and sometimes vital information, but we love to fix and banter. FTE, It's a great place.
What are your thoughts<?
Denny
