Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2001 Escape Oxygen sensor help please
Old Oct 8, 2018 | 10:04 AM
husker3in4's Avatar
husker3in4
I have a 2001 Escape XLT. Its throwing a code for Bank 1 sensor 2. I also have been getting reduced gas mileage the last year or so, which makes me think I may want to change all the O2 sensors. I think there are 4 sensors on this vehicle, and I have found them being sold all 4 in a package (2 upstream and 2 downstream). Can someone tell me if both upstream sensors are interchangeable with each other?Does anyone have a diagram of where they all are and which one is which?
Old Oct 9, 2018 | 05:55 AM
projectSHO89's Avatar
projectSHO89
Post the actual fault codes if you don't know for certain what you are doing (which is evident).
Old Oct 11, 2018 | 08:48 AM
husker3in4's Avatar
husker3in4
Thanks for your reply. I have 2 codes:
P2270 O2 Sensor Signal Biased/Stuck Lean Bank 1 Sensor 2
and
P2271 O2 Sensor Signal Biased/Stuck Rich Bank 1 Sensor 2
I know this is on the downstream so its more about emissions than gas mileage. I have 140k miles and still on original sensors so I figure Id just change them all at once. I can visually see them if I look, Im just not sure exactly which one is which.
Old Oct 11, 2018 | 10:37 AM
projectSHO89
It's more likely that spark plugs may need to be changed instead of all 4 O2 sensors assuming you have a V6 (not specified) in regards to fuel economy. How old are the plugs?
Are you sure about those codes (and the model year)? Ford's service documentation shows those codes as first being used for the 2003 model year.
happylogan1
1978 - 1996 Big Bronco
Jul 20, 2009 06:29 AM
ericnj75
Aug 31, 2007 03:03 PM
Drizzt
3.8 & 4.2L V6
Feb 15, 2007 02:14 PM
pilot815
Jun 20, 2005 06:53 PM
superrangerman2002
General Automotive Discussion
19
Feb 18, 2005 10:03 PM
