08 Escape finally popped codes. Continued thread
So 2008 Ford Escape. 3.0 V6. Had issues with it and I have repaired some. On the way to work this morning the check engine light finally came one and flashed indicating misfire. I have the following codes and I’ve looked at them
P0174
P0306
P2272
Basically they are lean and misfire codes.
All on the same bank I believe and the cylinder 6 misfire I had before. I installed a new coil and all the spray plugs.
Since that didn’t seem to fix the misfire issue I’m thinking I have a problem with the cylinder 6 Fuel Injector. Either a bad/clogged injector or bad wiring somewhere. Has anyone ran into this.
P0174
P0306
P2272
I have not run into this on an Escape but my neighbor had this just a couple of weeks ago. We removed the intake manifold and one of the wires to the injector was broken.
If the wiring looks good and you're feeling lucky you can swap the bad injector with a known good injector and see if the issue follows.
cabloom300
01-24-2014 06:39 PM
