Sponsored by: Real Truck
both back rims getting hot
Old Oct 8, 2018 | 06:38 AM
steff503's Avatar
steff503
Noticed brakes were smoking a bit a few days ago on my 2000 F350 but then it stopped.
Yesterday both rims were too hot to touch.
Any idea what would back both brakes hot other than just bad timing?
Old Oct 8, 2018 | 07:50 AM
02TB250's Avatar
02TB250
Your calipers are more then likely seized. I'd recommend replacing the entire setup pads rotors and calipers. If they were hot enough to smoke and are still getting to hot to touch you've probably sustained some damage to the components.
Old Oct 8, 2018 | 08:12 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Also check you emergency brakes - could be a stuck / seized emergency brake cable.
Old Oct 11, 2018 | 09:47 PM
droldsmorland's Avatar
droldsmorland
These high-quality trucks are notorious for the low-quality caliper bracket floating pins seizing. I guarantee it's your problem or a large part of it. Very poor design.
If the seized parts got the brake assembly hot enough, replace the pads calipers and pins. Inspect the soft line too. They can collapse internally. I have seen this issue get hot enough to melt an axle seal.
Old Oct 12, 2018 | 12:55 AM
Shovelheadrob's Avatar
Shovelheadrob
Of both rather than just one is getting hot then you likely need to look at a common denominator, either e brake cable or the flexible brake hose that runs from the body to the axle is breaking up internally & retaining pressure.
Old Oct 12, 2018 | 09:55 AM
Yendra Built's Avatar
Yendra Built
Always check for residual pressure in system before anything else. Jack up a wheel and see if it turns stiff, crack the bleeder and see if it turns free. Then go after the mechanical things.
OneTonCamper
Oct 22, 2014 06:44 PM
Moto52
Jul 26, 2009 08:49 PM
brian931
1983 - 2012 Ranger & B-Series
May 31, 2007 08:41 PM
greg F150
1997 - 2003 F150
Aug 7, 2005 03:21 AM
Will_01_GT
1978 - 1996 Big Bronco
Apr 25, 2004 05:11 PM
