Rear shock mount location. HELP!!
Old Sep 25, 2003 | 07:58 AM
tlicitra's Avatar
tlicitra
Hey guys! Well, I guess I didn't take enough pictures when I disassembled "the Beast". I am swapping out the stock rear for a Ford 9" rear. The 9" came out of a '62 F-100. I am putting it into a '53 F-250. My old rear end had no shock mounts, but the new one does. (welded right onto the housing) I know that the top end of the shock bolts up under the frame. Will I bolt the bottom end into the shock mounts on the new 9" rear, or do they need to go elsewhere. I already sandblasted the housing and was going to take it to be powder coated when I noticed the difference. Where did the bottoms of the shocks used to bolt in? I only had one left on the truck when I got it, and as I remember it was dangling from the frame. Thanks everybody! T
Old Sep 25, 2003 | 08:26 AM
Earl's Avatar
Earl
The lower end should go to the U-bolt cap as shown in the figure below.
Old Sep 26, 2003 | 06:36 PM
darkman's Avatar
darkman
Shock mounting Studs?
Anyone know if the upper and lower shock mounting studs are available anywhere?
Old Sep 28, 2003 | 04:24 PM
Scot's Avatar
Scot
The 9" tube is larger than the Dana 44 tube. Some of the late '50's early '60's trucks used this type of mount. Otherwise you can get them aftermarket.
Old Sep 29, 2003 | 06:49 AM
ke6bnl's Avatar
ke6bnl
I welded my shock mounts in the same location that the rearend clamps had placed the shocks originally. but I did measure the hold down for the rear end on my f3 and it seems like it would fit the 9" exactly.. Good luck Ed ke6bnl
Old Sep 29, 2003 | 10:19 AM
Earl's Avatar
Earl
Ed, I think the tube on your F-3 is the same as a 9", but the F-1 with the Dana 44 has a smaller tube.
Old Sep 29, 2003 | 04:13 PM
ke6bnl's Avatar
ke6bnl
Yes you are corredt the f1 has a smaller tube diameter. I will be will to sell my spring hold downs with the shock mount built in if intrested for the f1. Ed ke6bnl@juno.com
kabur66
6.7L Power Stroke Diesel
Sep 19, 2013 06:29 AM
warren561
Sep 12, 2013 08:39 PM
gmammakn
Jun 25, 2012 12:04 PM
boaterbob
Mar 20, 2011 10:36 AM
RangerPilot
1983 - 2012 Ranger & B-Series
Sep 3, 2006 04:11 PM
