shock mount placement
Old Mar 20, 2011 | 07:55 AM
boaterbob's Avatar
boaterbob
Going to weld new spring perches and shock mounts on my 53 with ford 9". New shocks are already on the frame. When setting the mount on the rear housing should i pull the shock out about 2" and set the mount there? what is the procedure? Thanks
Old Mar 20, 2011 | 09:53 AM
BBKtech2's Avatar
BBKtech2
Your close! I like having 3" either way. A 3" bump and extension is pretty standard when setting up shocks. Keeping your shock angle around 25-30 degrees helps their effectivness.
Old Mar 20, 2011 | 10:36 AM
AXracer's Avatar
AXracer
Agree, you should have at least 3" of compression travel and a bump stop that mechanically limits the suspension travel to ~ 1/2" less than that. You never want to bottom out the shock before the suspension, a sure way to destroy the shock.
JLR1953
Mar 13, 2014 05:56 PM
tjustice
Offroad & 4x4
Dec 19, 2013 04:02 PM
Trustee
Oct 16, 2012 12:17 PM
400inatruck
May 24, 2012 10:31 PM
bigshotsho93
Oct 19, 2010 01:57 PM
