Cruise Control
Old Oct 7, 2018 | 03:16 PM
Fordication's Avatar
Fordication
Cruise Control
Hey Folks. My CC stopped working on my 93 Ford F150 4WD. I do not know when it stopped but I tried to use it on a recent trip and its not even trying to indicate that its on. I checked the fuse and the only thing I can think of is that I removed the load leveler box underneath dash used for pulling loads. However I think I used it after that. How do I start troubleshooting this issue? Thanks
Old Oct 7, 2018 | 03:43 PM
sandymane's Avatar
sandymane
If your horn is not working along with the CC my issue was the clock spring. Replaced it and all was well. When I got my 91 my cruise wouldn't work and I pushed all the buttons multiple times and it started working. I would try your horn first. Sandy
Old Oct 7, 2018 | 04:03 PM
wtroger's Avatar
wtroger
Culprits can be brake pressure switch, brake light switch, clock spring, switches in the steering wheel , bad vacuum hoses, bad servo.
Old Oct 9, 2018 | 11:16 AM
Fordication
I will check it.
Old Oct 9, 2018 | 12:54 PM
jas88's Avatar
jas88
Manual or auto trans?
Old Oct 10, 2018 | 07:10 AM
Chuckus's Avatar
Chuckus
I will be watching this thread closely,my 87 f250 has the similiar issue, cruise control switch turns on but does not work.Horn also doesn't work.
Please post up your results.
Old Oct 10, 2018 | 09:22 AM
CamoF-250's Avatar
CamoF-250
how do you know it turns on? On my 92 I do not have a light that even idicates it has been turned on or set. It just works.
Old Oct 10, 2018 | 10:25 AM
johnnyfoodstamp's Avatar
johnnyfoodstamp
I replaced the turn signal switch to fix my blinkers not staying blinking while turning and it fixed my cruise control too. 89 f150
Old Oct 10, 2018 | 10:26 AM
johnnyfoodstamp
Old Oct 10, 2018 | 10:36 AM
CamoF-250's Avatar
CamoF-250
I guess you guys need to give him a chance to check the easy stuff first like his vacuum lines. There’s a vacuum line going from that brake petal vacuum release thing through your firewall to your servo. Then a short piece that wraps around the servo. The vacuum source is tee'd to a reservoir in front on your coolant tank. I am describing my 92 off of memory from redoing my vacuum lines.
Old Oct 10, 2018 | 10:37 AM
CamoF-250's Avatar
CamoF-250
What/where was the light indicating it was ever on?
Old Oct 10, 2018 | 03:50 PM
sandymane's Avatar
sandymane
I have no clue if the OP tried what I put in post #2 but those symptoms not working together is almost sure to be the clock spring has failed. Especially if you are sure they were both working previously. Sandy
Old Oct 10, 2018 | 04:04 PM
Fordication
Sorry guys. I got sent to a job in GA, right in the path of that storm and I will not be home for 2 weeks so I cannot do any trouble shooting. I will get on it as soon as I get home.
Old Oct 10, 2018 | 06:49 PM
Chuckus's Avatar
Chuckus
I have a light on mine that indicates it is on.It lights up but does not respond to setting speed.
Old Oct 10, 2018 | 07:26 PM
Eddiec1564's Avatar
Eddiec1564
What year truck you have?
You must have a aftermarket speed control. I never seen any trucks of this era with a speed(cruse) control indicator as factory. I even tried to make a indicator light but the way the speed control module is made, there was no easy way to do it.
