Alternator.
Old Oct 7, 2018 | 12:48 AM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
Post Alternator.
Need some help here. Just upgraded my headlights to the 50w Kensun Bi Xenon HID. I also need to replace my FICM as the scan gauge shows it jumping from 47 down to 43 and everything in between. The question is. Do I or should I upgrade my alternator? Not sure how old it is but told it is the stock oem. Bats are three years old too. If show what do you recommend and where to go? Thanks
Old Oct 7, 2018 | 01:16 AM
04badford's Avatar
04badford
Ditch the 110 alt , add the 140 amp , don’t want the ficm below 45v ever , same with Alternator on a full load nothing below 13.3, budget alt at Napa auto around 160.00 puts out 138 amp and so far been in the truck for 3 years .there are better alternators out there but had good results so far Napa premium, also Costco interstate battery’s are the best on price x2
Old Oct 7, 2018 | 01:18 AM
04badford's Avatar
04badford
Oh and Ed at Ficmrepair.com is the man ,
Old Oct 7, 2018 | 04:47 AM
ToolmakerRob's Avatar
ToolmakerRob
X2 on the 140 amp alternator.I would also suggest using a 54 MM pulley so it spins slightly faster. Jack(TooManyToys) has numerous posts/youtube videos and provides a wealth of information on the charging/grounding system and the improvements that should be done.
Rob
Old Oct 7, 2018 | 01:30 PM
Stroker 6.0 fan
Thanks for the input. I already decided to go to Ed at FICMrepair. Now to decide if I want Atlas 40 or just standard tune.
Old Oct 7, 2018 | 01:34 PM
Texas Bob's Avatar
Texas Bob
Based on the limited information you have provided, it appears that your FICM requires a repair or rebuild. That said, under performing batteries and alternator will kill your FICM. Charge your batteries up and have them load tested or check with a hydrometer if that is possible. As to the alternator, I would have it tested also. I would recommend a 140A Bosch AL7606N Alternator as a replacement. Check all of your wiring especially the ground connections.
As to sources, ED has a great reputation on this site for FICM work. I used a local guy near me in Garland, TX and I drove over there one night and picked it up the next night. That worked for me and it has been installed since 2013. As to the alternator, even if the alternator tests OK, I would put the Bosch on my Christmas list. It is available from Amazon at $162 and it has a lifetime warranty. It has been on my truck since 2014 and it is virtually plug and play. As to the batteries, you can decide on that based on your test. I am presently using batteries from East Penn Corporation and sold by O'Reilly. Others on this site will have a myriad of other recommendations. Good luck with your truck..
Old Oct 7, 2018 | 04:04 PM
Stroker 6.0 fan
Thanks for the info.
Old Oct 12, 2018 | 08:35 PM
Stroker 6.0 fan
One more question. When I start truck. Volts are around 13 but FICM amps show 38 to 40. When driving after a minute or so they go up to 44 to 48 and stay above 45. Batts tested and are good. Is this an alternator issue of is FICM going out? Just had new injectors installed a few months ago.
Old Oct 12, 2018 | 08:51 PM
04badford's Avatar
04badford
cold start your Ficm should never be below 45v , mine stays at 48.5, as the ficm heats up you will see better Volt out put , also look at the logic and vehicle side of the board those numbers will be at 12.0 , your alternator will draw when the gloplugs are on , once things are heated up they shut off and the alternator will Start the charge cycle , so cold start you might see 11v-12 v, on a full load engine warm /hot everything on fan, lights radio every light on in the house , you don’t want anything under 13.3, if in doubt bench test it , better save than sorry.
Last edited by 04badford; Oct 12, 2018 at 08:54 PM. Reason: checking the spell checker
Old Oct 13, 2018 | 12:54 AM
Stroker 6.0 fan
So i'm pretty sure the alternator is the original that came in truck. Sounds like the alt needs changing and up grading to the 140v from the 110 that is most likely in there now? Hopefully that will take care of the issue? I'm sure the batts are good. They are almost three years old now. I tested them and they show in the "good" range. My batt volts on the scan guage show 13.3 to 13.8 on average. Of course they drop on a cold start to approximately 11 then go back up.
Old Oct 13, 2018 | 04:19 AM
Stroker 6.0 fan
I see you had your FICM repaired by Ed. What tune did you go with? The standard or the Atlas 70? Im going to send mine into Ed but am on the fence as to what tune to go with.
Old Oct 13, 2018 | 12:08 PM
navistarnut's Avatar
navistarnut
Atlas 40 gets really good feedback from most guys. Glad I did it.
I went with a Remy 92529 alternator.
It's a 135V version and has the correct pulley on it already.
Old Oct 13, 2018 | 01:54 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I got my Atlas 40 straight from PHP, the other truck has a FICMrepair rebuild with Atlast 40. My truck was healthy when I did my tune so I honestly didn't notice a ton of difference (betterthrottle tip-in response was what I picked up on) but on the second truck, coming off a dead FICM that would run 45V and occasionally drop to mid-30s, the repair + upgrade felt like driving a rocketship.
I have an EGT gauge, I can be stupid and get to a warning point around 1200*f. But if I'm not stupid it's perfectly fine at any weight so far.
I have big alternators, a DC Power 270XP and a LN230. No regrets, not since we had three dead 110As and a dead 140A. One of the 110s was a poor quality reman IMO, it only made it like a year or two. The 140A was a factory unit dead before 100k.
Remember that alternator output voltage varies with battery health/age, battery temp, and alt/engine temp. In 11 years I'm on my 4th set of batteries, so three years is not out of range for them to have issues, especially if you had alternator problems at any point. Pull them from the truck, charge them, strip the surface charge, THEN load test. Popping off a lead and doing a load test in-frame on a warm battery after driving home from work is not necessarily an accurate indication of battery health.
Old Oct 14, 2018 | 02:11 AM
Euroman's Avatar
Euroman
Ive been getting around 2 years on a set of batteries, but after a FICM repair I'm sensitive about the voltage. After that they're good for many more years in a stress-free environment- tractor, electric fence etc
Old Oct 15, 2018 | 11:45 PM
Thor'sHammer's Avatar
Thor'sHammer
I have a DB Electrical 200 amp alternator. Everyone says its garbage, but those people seem to neglect to add the required 4 gauge wire as per the instruction booklet. Mine's been on for a year now, no issues and puts out 148 amps at idle speed (as tested off the rig).
FYI: Keep in mind, anything more than an Atlas 40 is NOT compatible with aftermarket tuning.
