99 F250 7.3l Chronic alternator(s) failing - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 09-13-2018, 09:20 PM
shadams3
shadams3 is offline
shadams3 is starting off with a positive reputation.
Greetings, First time posting a question. I have a 1999 F250 196,000 miles. I've replaced the batteries 2+ years ago. I've replaced the alternator "3" times with NEW alternators. Every 7 months or so the battery light comes on and off and on, till the alternator is replaced. Currently, I have had this NEW alternator in for about 3 weeks, Already my headlights dim and brighten as the battery light comes on and off and the voltage meter fluctuates up and down. The NEW alternators are from NAPA and are not rebuilt. PLEASE HELP
What amp power altenator should I be using? The alternators' I've been replacing are 110amp. Should I go higher? I do tow a 5th wheeler and an ATV trailer behind it. BUT!!! None of the altenator problems have occurred while towing.
Old 09-13-2018, 10:45 PM
brandonrr
brandonrr is offline
brandonrr has a good reputation on FTE.brandonrr has a good reputation on FTE.brandonrr has a good reputation on FTE.
What condition are your batteries in? Weak batteries and corroded or loose terminals will work an alternator harder and make running voltage less stable. Charging will be slower from high resistance which wastes power and creates extra heat. Heat kills alternators and batteries.
edit: just noticed the batteries are fairly new. It still wouldn't hurt to have them tested if you don't find any issues with the battery terminals, ground connections, wire condition, corrosion, etc.
Old 09-14-2018, 10:54 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is online now
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
You'd be a good candidate to do the new cable routing with alternator feeding the batteries..maybe Y2K or Sous can post a pic of what im tryn to describe
Old 09-17-2018, 02:25 PM
Josh Ross
Josh Ross is offline
Josh Ross is starting off with a positive reputation.
Following this one!
Old 09-17-2018, 03:26 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Y2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputation
As requested, photos of what cured all alternator and battery problems.
Upper Alternator:
(New alternator did not come with pulley, so this is how to harvest and remount the old pulley from the OEM alternator to the new alternator without over or under torque from an impact wrench).
Lower Alternator:
But remember... the cure for electrical weakness could end up being the cause for glow plug failure.
Old 09-17-2018, 03:30 PM
viperman86's Avatar
viperman86
viperman86 is offline
viperman86 is starting off with a positive reputation.
even a 6 month old battery can be bad. Sounds like the alt is working extra hard. I would load test both batteries first. Also check for corroded connections.
Old 09-17-2018, 06:34 PM
hydro man 17
hydro man 17 is offline
hydro man 17 has a good reputation on FTE.hydro man 17 has a good reputation on FTE.
I was not aware that NAPA sold NEW OEM alternators.
Old 09-17-2018, 06:51 PM
DieselDenny
DieselDenny is online now
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Whoa, that's a beautiful lifelong fix!!
Nicely done and thanx for sharing! When my unit ails, I'll be spot on with your post.
Thank you from all of us (most of us)
Denny
Old 09-17-2018, 08:23 PM
shadams3
shadams3 is offline
Thanks
Many thanks to everyone! The battery terminals are squeaky clean and the alternators' from NAPA are their name brand not OEM. I will have the batteries load tested as advised! I thank all y'all for your input and experience!!!
Old 09-17-2018, 09:01 PM
DieselDenny
Shad.
Key lesson from the extent of the above post is............
Battery terminals can play a bugle cleaned, but if the rest of the system isn't as sanitary, it just won't play a tune. Dig into every ground and your starter connections as well as anything that has +/- voltage and spend some time.
Believe me. Everything lasts alot longer. Follow your Neg cables to termination and inspect along the way. Do the same as suggested with the pos side. Definiely pull cables and clean your starter connections and treat them.
Guarantee you, that thing will charge like a new truck and your starts will spin faster.
Denny
Old 09-17-2018, 09:07 PM
shadams3
shadams3 is offline
Thank you!
Denny,
Many thanks for the insight and experience! I will spend this Saturday doing just as you advised!
Old 09-17-2018, 09:24 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
They don't! They sell new clones that are made in very nice third world countries with awesome quality control. It's the same alternator you can get from DB or Fleabay. The bridge rectifier is so cheap its bound to fail. Someone opened a OEM and an aftermarket and compared. Lots of internal differences.
Old 09-17-2018, 10:01 PM
97-psd's Avatar
97-psd
97-psd is offline
97-psd has a good reputation on FTE.97-psd has a good reputation on FTE.
Check the alternator connections. If they are loose then you should look at replacing the pigtails. Loose connections will cause the battery light to flicker and can cause charging issues
Old 09-18-2018, 11:44 PM
'88 E-350
'88 E-350 is offline
'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.
I assume they're testing the failed alternators before giving a warrantee exchange; do you know what in them failed? Knowing what exactly is failing could point towards the cause of failure.
Old 09-19-2018, 11:57 AM
shadams3
shadams3 is offline
Not testing
Great point but they're not testing the bad altenator, just a straight switch new for old.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
