Overheating Help
Old Oct 11, 2018 | 06:39 PM
Graplr's Avatar
Graplr
I'm attempting to put the MotorCraft fan clutch on. Issue I ran into is the fan bolts that attach to the clutch are the wrong size? On the old clutch it was 13mm to get off and they are much too thick to go into the new clutch.
Anyone else have this issue?
I suppose the old clutch is a knock off since the new Motorcraft is OEM and thus the bolts were replaced? Looks like I need new bolts unless someone knows something I don't?
Old Oct 11, 2018 | 06:51 PM
wpnaes's Avatar
wpnaes
Must be the case, I was able to reuse the bolts from the original to the replacement motorcraft.
Old Oct 11, 2018 | 07:16 PM
Graplr's Avatar
Graplr
Unless they sent me the wrong clutch? Do you remember what size bolts you used?
Old Oct 11, 2018 | 07:23 PM
Graplr's Avatar
Graplr
The box it came in was labeled with the correct part but the clutch itself doesnt have the part number on it.
Old Oct 11, 2018 | 07:47 PM
wpnaes's Avatar
wpnaes
13mm or a sloppy 1/2 inch. Note the last post in that thread.
https://www.ford-trucks.com/forums/1...l#post15048442
Originally Posted by High Cetane
+1
Dorman V10 fan, pn 620-159, needs the 4) holes for attaching (to clutch) reamed out.
Fan came w/ 17/64" dia holes, but requires 11/32" for the fasteners..as is the OEM fan.
If your going to R&R the fan without pulling the shroud (or clutch), this will save you aggravation.
Old Oct 11, 2018 | 08:06 PM
Graplr's Avatar
Graplr
Great info, thank you.
The ones I took off were 13mm as well but obviously the diameter was different.
Old Oct 11, 2018 | 08:55 PM
wpnaes's Avatar
wpnaes
Unfortunately I think he’s talking about the white, plastic fan blade unit.
Old Oct 12, 2018 | 02:24 PM
Graplr's Avatar
Graplr
I went to the pick a part to look for bolts and guess what? Both v10 Ex's had the same size I pulled off my fan. Checked a few expeditions v8s and they were the same size. Checked an f150 and it was the same.
Either they changed the bolt size or i got the wrong clutch in the right box. The front looks identical so I'm guessing they changed the bolt size?
Old Oct 12, 2018 | 09:52 PM
wpnaes's Avatar
wpnaes
I’d take it to the local hardware store and get 4 new, hardened bolts in the size needed.
Old Oct 12, 2018 | 11:32 PM
Graplr's Avatar
Graplr
Did that on the way home from the pick a part
It was M6.6 bolts. I got 20 mm length I believe, as that was the shortest they had. They should work with the lock washers. But I left town for a few days so it'll be a couple days before I try to mount the fan.
tbm3fan
Oct 28, 2014 12:40 PM
93F150/302
16
Nov 27, 2007 09:09 AM
eagleshavelanded
Aerostar
13
May 22, 2007 11:44 PM
bjepple
Dec 11, 2004 10:18 PM
tatesomero
1983 - 2012 Ranger & B-Series
Jul 10, 2004 11:05 AM
