Ez Lynk Tyrant vs GDP
Hi Everyone,
This is my first diesel and I am looking to do a delete. I read up a lot about the different tunes and tuners and it seems I narrowed it down to Ez Lynk with ether Tyrant or GDP. I tried searching for this but cant really find what I am looking for. I would really like to know what the main differences are between them and what everyone seems to prefer? Do both of them also Interact with the TCM? Not looking for anything crazy that will hurt the engine but a little more power over stock would be nice
. I only tow max 5k lbs a few times a year. Any input is appreciated.
Thanks,
Justin
. I only tow max 5k lbs a few times a year. Any input is appreciated.Thanks,
Justin
For the record I don't have either, I'm running spartan. But I follow allot of 6.7 forums and don't ever hear anyone complain about tyrant. A buddy of mine has tyrant on a job 1 2011 and loves them, his truck drives great
I have both Tyrant and GDP tunes for my 2015 F350
Both are great. Love the Tyrant ones, currently running regular GDP SOTF and really like it, great shifting and good mileage.
you can’t go wrong with either company.
GDP Customerservice through EZ Lynk is great...answer any questions pretty much instantly.
I am still a little torn but leaning towards GDP. Does tyrant support SOTH? Can you notice an real differences between them? Where did you get your GDP tunes? I think I saw them listed on xtreme diesel with the ez lynk 2.0. I guess they have a newer version of the ex lync now? Thanks again for all the help!
PPEI supports SOTF. They sent an email this week about an updated tune. I downloaded it through the Ez-Lynk and it's fantastic.
Only thing you can't tell what level your on.
With GDP SOTF tunes the "TS" channel tells you what level your switch is set at; 1 to 5.
GDP uses a fuel temp style SOTF switch.
Tyrant uses a CAC style SOTF switch. There is now a CAC TS channel on Auto Agent.....but it doesn't work with Tyrant SOTF tunes......yet.
Hopefully they will utilize this in the future. I have asked them....no response yet.
It's nice to see it switch levels so you can confirm your switch is working.
I got 16 files from GDP.
I ran the Regular GDP SOTF V2.3 for over 1000 miles.
Works excellent. Great shifts, no visible smoke, and as stated the TS channel shows what SOTF level your switch is on.
Both Tyrant and GDP are excellent.
If you want to run SOTF files mostly, I would lean towards GDP right now...... simply because I like the TS channel showing me what level I'm on, and it confirms the switch is working.....as the pins are finicky and don't seat well. So when I switch back and forth from the fuel temp to CAC style SOTF switch, it's nice to see it's working. As the test light on the back of the GDP switch doesn't always seem to work....when the TS shows it is indeed working.
If you want a staright tune....I'd go with Tyrant.
That's my .02 cents : )
Hope all that makes sense.....and your not more confused now than before ; )
Also I bought my GDP tunes through a dealer near me in Canada.
If you go to GDP's website it shows a list of dealers that sell them.
They will link direct from GDP to your EZ lynk via your EZ Lynk serial number......or truck serial number.
You just download and install the file you want.
When there are updates to a file, you will get notified of the update, then if you want you can replace the old file with new one if you have it loaded on your truck.
All very simple and straight forward.
Hardest think is installing the SOTF switch and getting it working....if you want SOTF,
I have it as I tow trailers for work.
So I run +200 for non tow miles and +75 hp for towing.
Figured out how to see what level your on with a CAC SOTF switch
Monitor "Charge Air Temp Voltage"
On the 0-210 Tyrant tune it's as follows:
Level .........Voltage
1...................2.1
2.................. 1.1
3 ..................0.6
4.................. 0.2
5 ..................0.1
Thank you everyone for all of your input! I think I am going to go with GDP. Does the throttle response change as well? Right now with stock if I floor it quickly it has that built in delay. Will that go away or be reduced? Also what other tunes are included with GDP tune pack? I knew about the 5 power levels but didnt realize they included 16 tunes.
My throttle is a lot more responsive with the GDP tunes. Once you have the programmer you will see all the tunes. Some are single power level emissions tunes, single power delete tunes, and on mine I have three different tunes to use the SOTF switch with. One is LBF (Low Boost Fueling) which is the super smoke/coal rolling tune. Another is the HISS tune which caused issues with my VGT. Now I'm on the other "low smoke" tunes, which are the least responsive, but a lot less smoke and so far no VGT sticking. There are also different trans shifting programs. I haven't found one I'm really happy with yet.
