OBS PSD in a E99
Old Oct 3, 2018 | 05:32 AM
udsuth78's Avatar
udsuth78
OBS PSD in a E99
i got the news yesterday that the 7.3 in my E99 is bad. I've been looking around at my options and I think I'm just going to get a used motor to just get it back on the road ASAP. this is my work truck so the down time is killing me. so my question is how much would I need to change if I were to use a 7.3 from an OBS PSD. so far I've found that I'd need the intercooler stuff, fuel system, and injectors from the E99. is that correct and are there any other parts i'll need or want to swap? thanks for any input
Old Oct 3, 2018 | 07:43 AM
Tugly's Avatar
Tugly
You need to cover the hole for the original fuel pump cam, but that's minor. The driver side exhaust manifold is different, so that has to be swapped/replaced. The intake plenums are 2" on an OBS. I have a 2000, so I bought 3" 8-bolt plenums from Riffraff Diesel. Older OBS engines have 8-bolt intake plenums, where the later engines (including SD) have 10-bolt. The oil pickup is different between the OBS and the SD - but I don't know if you need to change anything if you change the oil pan. The HPOP is different in a big way, so you want to keep the SD HPOP. The OBS UVCH is 2 connectors per head, where the SD has 1 each.
Old Oct 3, 2018 | 08:04 AM
z31freakify's Avatar
z31freakify
Just use the OBS long block and install everything from your E99, and plug the hole where the old pump on the OBS was.
Old Oct 3, 2018 | 09:02 AM
duck fan's Avatar
duck fan
Because racetruck
What year OBS as there are differences between them.
Old Oct 3, 2018 | 10:55 AM
udsuth78's Avatar
udsuth78
I've seen a 96 and a 97 on Craigslist but haven't called about them yet. The 96 is complete with supposedly only 125k for 1500
Old Oct 3, 2018 | 01:12 PM
Bonanza35's Avatar
Bonanza35
Whats wrong with the old motor?
Old Oct 4, 2018 | 05:37 AM
udsuth78's Avatar
udsuth78
compression in the #5 & #7 is bad. (160 & 260) the rest aren't great either low to mid 300s. I had the shop hook the cylinders up to shop air and it was blowing right through to the crankcase. this is my work truck and I need it on the road ASAP so just dropping in another motor seems like the quickest option. I plan to open up the bad motor later to see what happened and see if its rebuildable. having a fresh motor waiting on a stand is never a bad idea in my book.
Old Oct 4, 2018 | 08:25 PM
Firefighter 1406's Avatar
Firefighter 1406
Sounds similar to my disruption recently. My Early bird ended up having a couple broken oil rings causing low to no compression. I agree with the statement about, just swap over everything you can and go with it. They really are not that bad of motors to pull.
bubba_3711
27
Feb 17, 2016 08:56 AM
cwheeler96
52
Apr 23, 2014 01:53 PM
Leont
Sep 19, 2013 09:44 PM
genscripter
Oct 28, 2012 04:20 PM
ky79
Kentucky Chapter
Sep 24, 2010 03:59 PM
