Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F8000 vs L8000
Old 10-02-2018, 08:10 PM
Jeffrey Ferrell's Avatar
Jeffrey Ferrell
Jeffrey Ferrell is offline
F8000 vs L8000
Difference, other than the obvious cab? Pull them side by side the other day, both running Cat 3208s
Old 10-03-2018, 08:40 PM
Destroked 450's Avatar
Destroked 450
Destroked 450 is offline
Cab, front end, radiator and support, fuel tanks are different, air tanks mounted differently.
Most of the differences are pretty obvious
Old 11-21-2018, 12:57 AM
shadyside1983's Avatar
shadyside1983
shadyside1983 is offline
I would expect that a LN8000 would be easier to work on as they were built from the beginning to be commercial trucks and worked on by union mechanics on hourly rates. F models are adopted from light duty trucks which are not as mechanic friendly. A tilting hood also makes engine access easier.
Old 11-21-2018, 09:02 AM
Jeffrey Ferrell
Ive come to understand that the F8000 is the 33k frame and engine size of the L8000. Yea the cabs are different but the tilt hood is also on the F800. Mine is VIN wise a F800, but it has a double frame and a 10L engine. So when it comes to ordering parts engine and chassis i have to go with the F8000 if its listed or the L8000. Cab is a F350, hood cowl is an F800.
its been a learning curve restoring this truck. Thank God for this forum!
Old 11-21-2018, 10:14 AM
Destroked 450
What year models are they and is the L model a L or LN.
F series with tilt front sounds like a 80's or 90's model but then I've never seen a 90's model with a 3208 Cat diesel so I'm guessing 80's model.
L series has a longer hood with the complete fender make onto the hood.
LN has a shorter hood with the back 1/4 of the fender attached to the cab.
The hundred numbers indicated the truck had a gas engine, thousand numbers indicated the truck had a diesel engine.
Later Ford quit putting the thousand numbers on the trucks and called them all hundred numbers.
Local mill I worked at has a 71 LT800 with 391 gas, 84 LT8000 with 3208 Cat diesel, 83 LNT8000 with 3208 Cat diesel.
The 94 L800 we have at the fire dept has a 8.3 Cummins diesel
I have a 93 F800 with a 8.3 Cummins.
Old 11-21-2018, 11:48 AM
Jeffrey Ferrell
Mines an 84. It was a custom ordered truck for a county in Mississippi, then sold to a farm there and modified to haul different types of trailers. Im not sure what the county had the truck designed for, but its an absolute brut of power. Besides the Cat, it has a split 6.14/8.41 rear end.
Old 11-21-2018, 12:21 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
I decoded the OP's VIN and Certification codes. It's an F800 diesel.
Old 11-21-2018, 12:32 PM
Jeffrey Ferrell
Yeah, its an F800. Just none of the parts stores can find any data on it unless they type F8000.
GuitarJesus
08-27-2016 11:26 PM
tiredolbiker
19
11-30-2012 09:46 PM
Joe T.
04-07-2011 09:33 PM
mymerc
07-17-2008 02:03 PM
JimG1098
06-05-2008 07:39 AM
Quick Reply: F8000 vs L8000
