Speedometer Adjustment on 2002 Excursion Help
Old Oct 1, 2018 | 08:14 PM
sae1856's Avatar
sae1856
Trailering
Posted this in the Regional Forum but no replies at all.
Hey guys. Going to be doing the X and modded C spring upgrade on the X and then going 35s. From what I have read it isn't hard to adjust the speedometer if you have the right scantool to access the ABS module. Local dealer told me "we don't do that."
Anyone in central NJ either have a tool I can borrow/rent or know where I can get it done?
Thanks!
-Mitch
Old Oct 1, 2018 | 08:18 PM
pirate4x4_camo's Avatar
pirate4x4_camo
A ford dealer told you they do not do speedometer adjustments ? Get a diffrent service adviser. Setting the Rev/mile is a easy 5 minute process.
Old Oct 1, 2018 | 10:53 PM
PrescottIce's Avatar
PrescottIce
It may be less of a "can't do" and more of a "won't do" for someone in the Risk Management department.
Will Forscan do it?
Old Oct 1, 2018 | 11:34 PM
pirate4x4_camo
Yes Forscan does it....at least the full Windows based program, have not tried on the Mobil app
Old Oct 2, 2018 | 07:55 AM
GregA's Avatar
GregA
Ditto on Forscan. I used it on my '01 when I went to 20" wheels. $30 cable and free software download (though I donated)
Amazon Amazon
https://www.ford-trucks.com/forums/1...-change-2.html
Old Oct 2, 2018 | 09:10 AM
sae1856's Avatar
sae1856
Trailering
Thanks for the info! I will check it out. Do we know if it works on the app too or just the windows version?
Old Oct 2, 2018 | 09:19 AM
pirate4x4_camo
https://forscan.org/comparsion.html
getting the extended license is just a matter of registering you download, Take a bit of reading to figure out how to do it but it is easy.
Old Oct 2, 2018 | 09:21 AM
PrescottIce
I can't say for certain about that particular feature, but the app has less functionality overall than the full Windows version. And the Apple version of the app has significantly less functionality than the Android version. While the portability of a smartphone or tablet is a great feature, it's worth it for some to buy a separate laptop for Forscan and the service manuals in order to have the most complete toolbox when it's needed.
Old Oct 2, 2018 | 09:36 AM
pirate4x4_camo
The link I posted above to Forscan shows the features of each device.
You will need a Windows 7 computer and the extended license to do any program changes to your vehicle.
for a win7 computer I bought a 10” Dell Latitude 2110 on ebay for $55 bucks ( they are plentiful school surplus computers ) and it is the perfect Forscan computer, the case is even rubberized so it doesn’t slide off the dash during test drives.
Forscan list 2 compatible USB adapters, I went with the obdlink sx
Amazon Amazon
Old Oct 2, 2018 | 10:43 AM
sae1856's Avatar
sae1856
Trailering
Also just to be clear, do I access and change tire size though the ABS AS BUILT or just ABS.
Old Oct 2, 2018 | 11:02 AM
pirate4x4_camo
Just the abs unit... it will be obvious when you pull up the correct menu
sae1856
New Jersey Chapter
Oct 1, 2018 01:19 PM
Scooter429
Apr 17, 2009 08:14 AM
RubberDuck
May 30, 2008 05:28 PM
69ford99
1978 - 1996 Big Bronco
Dec 14, 2006 01:59 PM
JohnApple
Feb 7, 2005 08:32 PM
