Flywheel?
Old Oct 1, 2018 | 06:38 PM
75 F100 4X4's Avatar
75 F100 4X4
Flywheel?
What size is my flywheel? I have a 75 F100 4x4, 360, 4 spd.. The flywheel is still in the truck and from my research it has 184 teeth however I have seen different diameters listed ie: 15.503" and 14.306". I would like to have the parts ready before pulling it off to avoid a delay in reaasembling. Hoping some one knows the answer. Thanks in advance for your help.
Old Oct 2, 2018 | 10:05 AM
Destroked 450's Avatar
Destroked 450
15.503 is the outer dia of the ring gear that fits the flywheel, 14.306 is the actual dia of the flywheel its self.
If your looking to replace the flywheel get one with the dual bolt pattern that will allow the use of a 11" or 11 1/2" clutch
If you only going to replace the clutch most came with the 11" clutch but there's no way of knowing until you've taken the old one out.
Old Oct 2, 2018 | 12:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5AZ-6375-K .. 352/360 Flywheel - 184T / Use with 11" clutch / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle / Obsolete
1965/67 F100/350 352; 1968/76 F100/350 360 // 1965/67 Galaxie/LTD 352.
C5AZ-6375-L .. 390 Flywheel - 184T / Use with 11 1/2" clutch / (6) 5/16" -18 pressure plate attaching holes on a 12 7/8" bolt circle / Obsolete
1968/76 F100/350 390 // 1965/71 FoMoCo 390 Passenger Cars.
390's were not factory installed in 1968/76 F100/250's with 4WD
blacburn10
Mar 26, 2013 12:00 PM
mark a.
WTB - Parts & other
Jan 31, 2012 08:43 PM
reecem13
Aug 9, 2008 09:05 AM
Fair 96
Feb 16, 2006 09:08 PM
socalcarnut
Nov 24, 2001 11:05 PM
