Water seeping through intake stud???HELP
Old Sep 30, 2018 | 08:15 PM
86F250 460's Avatar
86F250 460
Just got my 460 running again and when timing it noticed some water seeping out of front drivers side stud. The engine is out of a 76 Lincoln has original intake stud etc. I figure the studs are in a coolant passage? and just need some sealant put on the threads but want to make sure. When I took the engine apart some of the studs did come loose from the heads. Any advice appreciated. Thanks
Old Oct 1, 2018 | 05:08 PM
Franklin2's Avatar
Franklin2
Yes,try a little silicone in the hole. Most Fords have water going across the front top of the engine through the intake, tying into the thermostat passage.
Old Oct 1, 2018 | 09:44 PM
86F250 460's Avatar
86F250 460
Yeah I went out on a limb and pulled the stud and put some rtv on the threads see if it stops thanks for the reply
Smittys6.9
Feb 27, 2017 04:41 PM
97F250LD
Apr 12, 2009 04:08 PM
MARTINT
Apr 9, 2008 05:45 PM
thebeastof1980
Mar 28, 2008 02:10 PM
icuhatn99
Feb 16, 2006 11:54 PM
