I use a small cardboard box to rest my head on for that very reason, even then I manage to pinch a nerve in my neck and then my shoulder kills me..
NOTE: THIS DOES NOT REPLACE MEDICAL TREATMENT FROM A PHYSICAN!
Use an OTC medication for pain! Then take a towel and tie apposing corners together. Hang it over a door ****, then lay on the floor with your head about 1 to 1.5 feet from the door. Lay your head in this sling so it supports your head but is more toward the neck. the height off the floor should be 2-4 inches. This pulls the neck away for the body nd relives the pressure. twice a day for 5-7 days. typically you should have some relief after the first time.
Something like pulling teeth... I'll try and rig something up and give it a try. I have very degenerated discs and am very stiff..
