Max egt?
Old Sep 29, 2018 | 12:16 PM
17f2fiddy's Avatar
17f2fiddy
Max egt?
17 powerstroke deleted with ez lynk tyrant tunes, seeing about 1150ish wot on highway to 100mph. Is 1100-1200 safe zone? What’s the max egt on just tunes and delete before I see failure?
Old Sep 29, 2018 | 12:28 PM
rjrandy96's Avatar
rjrandy96
Max is 1250 aluminum melts at this you hit 1400-1600 for a few second not good for longevity, 1300 hundred maybe a min long. you stay under 1150 you can hold it all day tho
Old Sep 29, 2018 | 03:50 PM
senix's Avatar
senix
Before you deleted, during a regen 1200-1300 would be a normal EGT.
Old Sep 30, 2018 | 12:44 AM
cappa's Avatar
cappa
Depends if your towing or not. I wouldn't run sustained 1300 for hours but if you hit 1450 for 8 or 9 seconds it isn't going to hurt anything. I have my alarm set at 1450 and hit it every now and then. 60000km so far and running like a top. If I tow however I will drop the power to 1 and egt's should be safe as it's basically a stock tune. For the record I haven't done allot of towing with this thing thou.
Old Oct 1, 2018 | 08:47 PM
lariatbob's Avatar
lariatbob
Wouldn't that be post- turbo?
dustinsheeler717
Aug 16, 2021 04:39 PM
Shelby-GT-500
May 26, 2015 12:17 AM
carolinacamper
6.4L Power Stroke Diesel
40
Apr 8, 2013 08:02 PM
WH 6.0
Mar 28, 2012 12:37 PM
Dustball8504
May 15, 2008 01:09 PM
