Tips for installing engine into F250 4x4?
Old Oct 1, 2018 | 05:14 PM
Johnkimble's Avatar
Johnkimble
I got it! I massaged it to about 1/2" gap between the trans and bellhousing. I threaded in the bolts and slowly started drawing it together, alternating between bolts so I didn't bring in one corner before another.
All mounted! Thank you all for your suggestions!
Old Oct 2, 2018 | 12:50 PM
baddad457's Avatar
baddad457
Originally Posted by Johnkimble
Okay I will try that way. Thank you.
Don't waste your time doing this. Take 4 - 7/16" NC x 4 inch bolts, cut the heads off and chamfer the ends, then cut a slot in the cut end that can be used to unscrew them with a flat head screw driver. Put two studs on each side in the bell housing mounting bolts in back of the engine. Use these to align the engine to the transmission when you drop it in place. Once you have all four into the matching holes in the bellhousing, simply shove the engine onto the bell housing. I've installed a half dozen engines like this in two different vehicles by myself (yes, alone) I used old long small block head bolts to make these alignment studs. You can also use them to align the transmission to the bell housing.
Old Sep 21, 2019 | 02:10 PM
demonwaif5's Avatar
demonwaif5
Sorry to revive an old thread.
Johnkimble- Did you notice your motor perches being not even? I have a 1974 F100 4x4 and a FE428 and am noticing the engine sits tilted lower toward the driver side. I just want to confirm with other owners that this is indeed a common thing Ford did. Thanks!
Old Sep 21, 2019 | 05:00 PM
Johnkimble's Avatar
Johnkimble
I did not notice the perches being uneven. The engine is definitely level left to right. How off are your perches? Do you have a thread going on your build?
Old Sep 21, 2019 | 10:45 PM
demonwaif5's Avatar
demonwaif5
https://www.ford-trucks.com/forums/1...gine-tilt.html
here are some pictures from a thread I started.
bren_tx
1997 - 2003 F150
Mar 27, 2018 01:53 PM
GoldCo
Nov 15, 2016 12:51 PM
psmith0803
Large Truck
Jun 4, 2013 07:56 AM
ErrorS
1978 - 1996 Big Bronco
Oct 15, 2009 10:35 AM
supercab78
Mar 8, 2006 09:01 AM
