compliments what is this ? post
second: I have installed a Pertronix breakerless unit, should I eliminate this "filter" ?
third: will a voltage reading with a digital multimeter on the plus terminal reveal to me if there is built in resistance in the ign. circuit ?
the Pertronix installation instructions wants the unit to receive a full 12 volts to its red wire & I am hoping I wont have to run a new dedicated wire from ign. sw. to red wire !
THANKS in advance!
I tried to paste a copy of the schematic but got an error message " to many characters".
I'll mess around little and try again.
AM radios, and FM to a lesser extent, had a REALLY hard time with ignition noise.
The above also goes for the condensor inside the distributor. It is meant to help stop arcing as the points open.
A few questions : the circuit that goes from ign. sw. to coil plus terminal 1978 f600 (389xd) is in series with this "filter" Is that correct ?
THANKS in advance!
What PERTRONIX is saying is that it's module wants to see 12V (also consult directions for coil voltage). Depending on the model year of the DURASPARK, voltage can vary. V was increased year-by-year (through a resistor) as the DS produced a hotter spark.
Does the instruction sheet specify 12V or full BAT VOLT? There is a difference.
That capacitor has nothing to do with the VOLT. It is only a radio interference filter so you can enjoy your RAP MUSIC.
I listed the capacitor part number (D5AZ-18832-A) and applications in another of the OP's posts.
To be more specific: the instructions said to put red wire before a ballast resistor so I assume that would also apply to resistance wire, therefore how do I determine it has R with a voltage reading ?
