94 F250 Code 334
Old Sep 26, 2018 | 08:21 AM
steveamann's Avatar
steveamann
94 F250 Code 334
The check engine light came on and it ran rough for about one mile went. Did key on Engine off test and got 334 10 512. Any help would be appreciated.
94 F250 5.8
Old Sep 26, 2018 | 08:56 AM
ZombieF150's Avatar
ZombieF150
334 = EGR closed valve voltage high
10 is a separator
512 = KAM test failure (Keep Alive Memory) which usually indicates your PCM is bad and needs to be repaired/replaced. That is the one I would concentrate on first.
Old Sep 26, 2018 | 09:16 AM
steveamann's Avatar
steveamann
If the PCM is bad would it do it all the time or intermediate times?
Old Sep 26, 2018 | 09:42 AM
ZombieF150's Avatar
ZombieF150
It can give wonky codes and make the CEL come on yes from what I have read.
Most posts I have read about it, it is caused by 3 capacitors leakig due to age and corroding the connections. Some replace the capacitors themselves. I bought a reman PCM as I needed the truck on the road ASAP. I am pretty good with electronics and soldering but it was a time is money situation.
Old Sep 26, 2018 | 09:52 AM
steveamann's Avatar
steveamann
Thank for the help.
Old Sep 26, 2018 | 09:57 AM
rla2005's Avatar
rla2005
Code 512 can be triggered by removing the battery cable then re-installing it. Some do this to clear the stored codes from Continuous Memory. The proper way to clear CM codes is to start the KOEO tests, then remove the ground on the STI connector as the codes are flashing out.
Old Sep 26, 2018 | 10:03 AM
steveamann's Avatar
steveamann
I will try thanks
Old Sep 27, 2018 | 04:55 AM
timemachine455's Avatar
timemachine455
Just had an issue running rough at idle. Got a 334 code. EGR was bad, sticking open. 93 F350,7.5
Old Sep 28, 2018 | 08:39 AM
steveamann's Avatar
steveamann
Update, we cleaned the PCM connections and used dielectric grease and replaced the PCV valve and all seems good now.
Old Sep 28, 2018 | 10:59 AM
ZombieF150's Avatar
ZombieF150
good deal. hope it runs well for you for a long time..
Old Oct 27, 2018 | 07:55 AM
steveamann's Avatar
steveamann
Turned out the problem was the distributor and plug wires
metriccar
32
Mar 7, 2026 07:56 PM
steveamann
Mar 15, 2014 09:42 AM
steveamann
13
May 5, 2013 03:33 PM
Redneck1465
Feb 8, 2010 09:05 PM
LWolffe
Aerostar
Jul 22, 2005 03:26 PM
