Super cab speakers
Old Sep 25, 2018 | 08:18 PM
2018f250stx's Avatar
2018f250stx
Super cab speakers
With all the talk about sound upgrades I'm looking to upgrade my speakers and add a powered sub, I had the basic radio with CD no sync. I've upgraded to a kenwood ddx9904s . Anyone know the size of speakers in the front and rear doors of a 2018 supercab ?
Old Sep 26, 2018 | 11:21 PM
NS70250's Avatar
NS70250
I’m also interested. The stock setup really lacks
Old Sep 27, 2018 | 07:02 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
According to Crutchfield, it's 6x9's in the front door and 6-1/2" in the rear.
I hope it's right, because I just ordered speakers 30 minutes ago!
Old Sep 27, 2018 | 11:27 AM
Mlambert22's Avatar
Mlambert22
I would try replacing the head unit with a powered unit or add an amp to push some power to the stock.. typically the stock ones can handle a lot more power then they are getting from stock, if you just replace the speakers but don't add anymore power you will be in the same boat you are in now
Old Sep 27, 2018 | 12:49 PM
Tricon's Avatar
Tricon
Not really, you can purchase speakers that are designed with high sensitivity in mind to try and squeeze out as much efficiency as possible. But I really doubt the stock speakers can handle that much more wattage without distortion. They are pretty dinky...although I'll be honest, I think they actually perform better than the Sony's at higher volume. Quite noticeably.
Best money spent would be a component set up front, with a 100ish watt x 2 amp, and a 10" wedge sub in the rear. I think this is the lowest form of stereo replacement anyone should do, since its not that much more money than just replacing the speakers, and its going to absolutely blow away a non amplified system.
There's quite a big difference in OEM and aftermarket, even these cheap Polk DBs are a massive improvement, look at that difference in the magnet and voice coil.
Old Sep 27, 2018 | 04:35 PM
2018f250stx
cool , post some pics
Old Sep 27, 2018 | 04:45 PM
2018f250stx
Already did, 4x50w and 3 5v preouts
Old Sep 27, 2018 | 09:48 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I did go against your advice in the other thread. I ordered the Polk DB 652's for my rear speakers. I just couldn't leave the stock ones in it with good consciousness
auburngrad
Apr 3, 2018 03:29 PM
woodsnake
Feb 11, 2016 06:22 PM
3/4ton4X4
Jan 6, 2015 08:10 AM
TallPaul
15
Aug 6, 2009 08:39 PM
matthew_ccu
Nov 16, 2004 03:18 PM
