Too nice to it??
Old Sep 25, 2018 | 04:33 PM
fyredude's Avatar
fyredude
Too nice to it??
Own a 2005 6.0l TD with 103K original miles. And I'm sure of it. I have always cared for my vehicles well as I do for this one. This is my 1st diesel. I pull a TT with a total weight of 8K. I rarely exceed 2200 rpms 'cause it seems like the right thing to do. Sometimes, when pulling a grade, my boost will reach 21 psi. I really thought it would pull better. Am I not pushing this engine hard enough or do I have a problem? Temps are within acceptable limits, have a new larger cat back exhaust set up, runs smooth as silk, is economical and I love it. However...…...
Old Sep 25, 2018 | 04:37 PM
tomsoftail's Avatar
tomsoftail
I guess you've almost never merged into route 93 traffic in my neck of the woods. 2200 RPM, sheesh! 0 to 65 mph would be about 14 second at that throttle.
Nice low mileage truck you must have there!
Old Sep 25, 2018 | 04:49 PM
fyredude's Avatar
fyredude
I would assume from your response (I think) that I am babying this engine. And you are right - this truck is spotless, in and out. It has never seen snow, salt, sleet and if possible, I don't let in get rained on.
Old Sep 25, 2018 | 04:57 PM
tomsoftail's Avatar
tomsoftail
Yes, good interpretation of my post. You're babying this truck!
I'm sure if you put yours next to mine it would be surprising to most that my truck is a model year newer. Of course I bought mine to work with and the unfortunate reality is that I can't justify the extra costs of another vehicle, taxes, maintenance, fuel and insurance to use as a daily driver. The finances and my cheapness don't allow it.
I'm amused when I see people that use these vehicles as a grocery getter. The vehicle costs that I already mentioned save for insurance, are too great for me to even consider this to be anything what it is; a work truck. It is a tool that helps me at work.
Every panel of my truck has a dent or a scratch and the undercarriage has slightly less rust than the Titanic. The interior is in good shape however. I do wash it and I do maintain it according to schedule but I'll repeat it is a work vehicle.
I'm guessing yours is worth more than mine by a mile too!
Old Sep 25, 2018 | 06:25 PM
fyredude's Avatar
fyredude
Thanks for your response! I can appreciate where you're at. My day to day vehicle is my wife's 97 Ford Explorer Sport. It is (I'm sure) in worse shape than yours. Being retired, I have the luxury of using the diesel for towing almost exclusively - either my boat or the trailer. I waited most of my life to acquire the diesel, which is why I baby it. Having said that, I still expect it to do what a diesel is supposed to do - pull! Not knowing how hard to push it, has always been my concern. I know the specs on the engine as to torque and horsepower. That is why I try to keep it close to 2000 rpms when towing, however that leaves no room for error on a good grade. The minute it drops below 1800 rpms, it turns into the equivalent of a gas engine. I guess it is time to wind her up and make it work. Thanks!
Old Sep 25, 2018 | 06:32 PM
packagerjr's Avatar
packagerjr
If you lug it at 1800 going up a grade with a load, your exhaust temps are going to get pretty warm, even on a stock tune. Don’t be afraid to make it downshift and run 2600+ rpm. Keeps more air moving and at least can stabilize EGTs.
I tow about the same 8K trailer you do.
Old Sep 25, 2018 | 06:54 PM
ford390gashog's Avatar
ford390gashog
At 2200 rpm how do you expect to keep the VGT clean? I advocate WOT on a somewhat often basis to keep things running well.
Old Sep 25, 2018 | 07:24 PM
kd0axs's Avatar
kd0axs
Agreed. These things are made to work. Don't be afraid to give 'er the good ol' Italian Tune-up once in a while.
Old Sep 25, 2018 | 08:43 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
You're not doing anything wrong, you just aren't getting the most power output possible. Don't be afraid to let it rev higher and work more when you need it to - that doesn't mean stomp on it and abuse it constantly, but letting it work when you need it is fine. 2000rpm is right around the torque peak so it's a good, stable RPM for cruising, even with a trailer on. If you can handle the slow starts it can be very economical, you don't need to mash the pedal to the floor every start. But when you need to accelerate to merge or get up a hill, let the transmission do it's thing and downshift and run higher RPMs until you get to the top. The PCM won't let the engine overspeed.
natecarlson
Mar 6, 2019 02:41 AM
jschira
All Things Towing
19
Aug 18, 2018 10:14 AM
Winchesterm1873
13
Jul 19, 2016 07:01 PM
the_auto_tech
2009 - 2014 F150
25
Apr 19, 2015 03:18 PM
spittle8
2009 - 2014 F150
15
Feb 23, 2009 10:12 PM
