Engine harness disconnect question
Old Sep 25, 2018 | 04:29 PM
oldproudvet's Avatar
oldproudvet
This is the Left front inner fender on my '97 7.5. I need to disconnect this harness and can't for the life of me come up with the solution. The caps on ea end give you access to the backside of the wires entering the pins, after that I'm stumped. Thanks
Last edited by oldproudvet; Sep 25, 2018 at 04:33 PM. Reason: pictures didn't load even though upload was clicked and appeared successful
Old Sep 25, 2018 | 04:35 PM
oldproudvet
Sorry guys I can't the pic of the connector to post. Appears fine, click upload it appears just fine but does not appear in my post as other sites do. I'll keep trying tonight.
Old Sep 25, 2018 | 04:50 PM
oldproudvet
Problem with disconnecting engine harness
this is the Left inner front fender on my 97 7.5 I cannot figure out how to disconnect this harness. The end caps simple give access to the back side of the pins. Thanks guys......
Old Sep 25, 2018 | 06:19 PM
EPNCSU2006's Avatar
EPNCSU2006
There's a screw in the center of one side holding the assembly together. The screw runs parallel to the wires.
Old Sep 25, 2018 | 08:37 PM
oldproudvet
Thanks Eric, I'd loosened that bolt (on the firewall end) and it appeared to just loosen the cover, which was the back side of the pins. I did not attempt to separate the parts, will take a look in the morning.
GoldCo
Jun 16, 2017 08:23 PM
kbarbee95
Feb 11, 2015 11:10 PM
JeepScrambler
Oct 18, 2014 01:37 PM
dioxippus
Feb 18, 2014 06:50 PM
jkerkman
Mar 30, 2004 09:51 PM
