DPF Deleted
Old Sep 25, 2018 | 05:41 PM
UGA33's Avatar
UGA33
Originally Posted by 0835064
Hit up this email he sells a whole kit of plugs for everything!
shibbyutman@hotmail.com
Email this guy. Finally found a clean solution for this with their product.
brendanlush's Avatar
brendanlush
Originally Posted by Maximus216
how much smoke is coming from the exhaust now?
None really that I have noticed. I would assume if I really got on the pedal there would be some.
Old Sep 25, 2018 | 05:45 PM
brendanlush
Originally Posted by C_Smitty
If you know you're going to put the emissions back on at some point, then it's probably best just to block it off. If you have no restrictions in your county/state and don't see yourself putting it back on, then just remove everything.
I highly doubt that I will be putting any emissions back on as I live in Canada and there really aren't any restrictions. Especially where I live, Yellowknife we idle our trucks a ton in the winter. As of now, the computer has the EGR disabled but I will be looking into block off plates for sure.
Old Sep 25, 2018 | 08:03 PM
Tranz zam's Avatar
Tranz zam
Sweet, another deleted truck! One of the first mods to do on a modern diesel, is to take that crap off, fall back and hit a 3 pointer right in the trash with that garbage.
Old Sep 25, 2018 | 08:11 PM
brendanlush
LOL, I almost had to get a buddy over with his 50 ton crane to help me lift the damn thing!
Old Sep 26, 2018 | 07:42 AM
troverman's Avatar
troverman
Originally Posted by CBEllis
Did you block off or remove the EGR system or just leave it in-tact. The more I research the DPF and how it functions, the more disgusted I get. There is no possible way that a regen process is good for the longevity of the truck and I'm not convinced it's best for the environment either.
The "Ford" regen process is not as good, in my opinion, and the GM / Duramax design. GM uses a "9th injector" so everything is happening post-engine. Ford uses a less expensive route and injects extra diesel on the exhaust stroke so hot fuel has to travel out of the cylinders, and through the turbocharger, before exiting through the downpipe and finally being combusted in the DOC. This allows the potential for diesel fuel to dilute crankcase oil via blow-by, although the risk is minimized because there is virtually no compression...exhaust valves are mostly open.
I've also wondered about environmental impact when all that soot is "incinerated" and sent out the exhaust pipe.
most mechanics leave the egr on, but i think its just being lazy. as soon as my 36000 miles is up, def is gone
You do realize your engine warranty is 5/100?
Old Sep 26, 2018 | 11:48 AM
Tranz zam's Avatar
Tranz zam
Haha, I hear ya!
The reality is, the only reason your Super Duty would even need to go back to the dealer for warranty work is for emissions or death wobble. Ford cant seem to engineer a truck without it death wobbling, so there's no use in trying to get them to fix it. On the emission side of things, if there's no emissions equipment to malfunction, then there's no chance of warranty work needed!
Old Sep 26, 2018 | 12:30 PM
Busa 1 Dave's Avatar
Busa 1 Dave
Haha, I hear ya!
Just curious as you post about how great deleting the truck is and your knowledge of going back to the dealer for warranty work etc. are you speaking from experience of just what you read on the forums? Do you own a 2017 or newer that has Actually been deleted?
Old Sep 26, 2018 | 12:43 PM
Blwnsmoke's Avatar
Blwnsmoke
why 36k???
Old Sep 27, 2018 | 06:56 AM
Maximus216's Avatar
Maximus216
thats when the bumper to bumper warranty ends and hopefully all the kinks are worked out by then.
Old Sep 27, 2018 | 07:29 AM
Blwnsmoke's Avatar
Blwnsmoke
But the engine is 5yr/100k.. that's really the only concern about warranty being voided by a delete. 36k really has no impact on a delete. As long as you are willing to give up your engine warranty, no reason to wait till 36k.
Old Sep 27, 2018 | 07:37 AM
troverman's Avatar
troverman
^^That was the point I was trying to make earlier...
Old Sep 27, 2018 | 07:40 AM
  #28
Blwnsmoke's Avatar
Blwnsmoke
Somehow I missed your post. Only got notified of his reply. My bad lol.
Old Sep 27, 2018 | 08:29 AM
  #29
troverman's Avatar
troverman
No worries, I was just trying to remind him of the same thing.
teamlx88
25
May 20, 2010 10:51 AM
Sycostang67
General Automotive Discussion
Nov 19, 2006 08:33 AM
MEMO847
Jan 16, 2006 02:56 PM
CJK440
Modular V8 (4.6L, 5.4L)
13
Aug 13, 2005 10:49 AM
vlad 75
3.8 & 4.2L V6
Jun 28, 2005 05:22 PM
