P0193 code
Old Sep 25, 2018 | 06:30 AM
David St John's Avatar
David St John
P0193 code
I have a 2004 Ford Explorer Sport Trac V6 3L cut the p0193 code I am wondering since it's not having a problem starting or idling could it be the fuel filter I only have a problem when I'm driving down the road at a high speed 45 or higher and it sputters a little bit when I press on the gas.
Old Jan 11, 2019 | 03:15 PM
jcris's Avatar
jcris
I would suggest just replacing the fuel filter as general maintenance. I think there supposed to be done every 30-40K miles
Old Jan 11, 2019 | 09:37 PM
shorod's Avatar
shorod
It would be unusual for a restricted fuel filter to cause a P0193 as that code is typically set by either too high of a fuel pressure or a faulty fuel rail pressure sensor. When is the last time you replaced the spark plugs and plug wires? Have you ever cleaned the MAF sensor?
-Rod
mhofmann86
Sep 22, 2015 03:45 AM
stevorino
Dec 16, 2012 11:18 PM
ironmine
Apr 19, 2008 10:19 AM
ctboyle03
1983 - 2012 Ranger & B-Series
Mar 22, 2008 06:51 PM
