so i have a 1996 ford f-150 4x4. roller block. i have a set of bbk short tube headers that i am putting on it soon. and i’m re-doing the exhaust. i am having a hard time finding an after market y pipe to use. i have seen people use the manga flow and the bassani but i would like some other opinions on some other possible options that maybe are less expensive.
wanting to replace y pipe because my cat leaks and i figured it would be easier to just buy a new y pipe rather than to cut the y pipe before the cat and merge the two pipes back into one.
in a perfect world i would just run a pipe pipe from each header going back but with my driveshaft being right there i don’t really have room.
am i better off to build a whole new y pipe? modify the one that i have? or buy a new one? idk. i’m open to every and all opinions. just looking to see if anyone is thinking of something that i’m not. thanks in advance
The converter that fits that h-pipe can be expensive since it is not as common as the single inlet like the Bronco/F-150.
That Walker y-pipe will also need modified to move the front O2 sensors to the factory location. Then a third one will need to be added behind the converter. By the time you add the modifications to make it work, you might as well go with a 1996 specified y-pipe/converter setup.
When I swapped my 300 for the 351 from the F250 of the same year, I retained the F250's engine harness and it has the one rear A/F sensor located in the balance tube of the H pipe. I welded the 300's catalytic converter onto the remains of the cut out portion of the cat that was still bolted to the H pipe and surprisingly, it works as a muffler as well.
Your truck uses only one O2 sensor that is used by the computer for air/fuel feedback to the computer. The OP has a 1996 F150 that is OBD-II and uses three O2 sensors. Left & right bank fuel/air feedback and a third O2 sensor to measure converter efficiency. That's why I pointed out using the suggested h-pipe would require some modifications to work in their application.
No surprise there. The factory converter(s) are well known as effective mufflers.
$236 USD is a chunk of change in my book. Better than $400+ for a California emission version. Many universal single inlet/out converters are in the ~$125 range, some even less. Would they work on OBD-II vehicle? Good question.
BTW I have no check engine light issues with my set up and thankfully KY has no emissions testing....
Your truck uses only one O2 sensor, that you did install. There is no provision for measuring converter efficiency on your truck so you could have eliminated the converter completely and the computer would still be happy.
