Distributor paranoia
Old Sep 22, 2018 | 11:06 PM
okie trucker's Avatar
okie trucker
Cool Distributor paranoia
Hey guys, my helper removed my distributor to replace vacuum advance but he didn't mark it very well. Now the engine won't start and I.m wondering how to verify my paranoia. Also, does the #1 plug supposed to face front of engine ? Distributor cap is my first concern. Hopefully I can get her started by repositioning the "D" cap.
Old Sep 22, 2018 | 11:46 PM
Tedster9's Avatar
Tedster9
What engine? On V8 the cap only fits one way afaik.
Start from scratch might be best. Roll the engine over by hand till the #1 piston is at TDC on the compression stroke. then drop the distributor in with the rotor pointing at the #1 terminal location.
Old Sep 23, 2018 | 12:59 AM
ford390gashog's Avatar
ford390gashog
FWIW the distributor doesn't care which post is number one. You can pick any post and set the rotor to it at TDC and then set firing order off of that.
Old Sep 23, 2018 | 06:38 AM
User 71024's Avatar
User 71024
Does it have any particular engine in it? Or should we guess ? Instructions are better if we know what we're working on.
Eric
Old Sep 23, 2018 | 09:33 AM
okie trucker
It is the 292 Y block, even with all this good info I still need to know if distributor cap has #1 plug wire facing front of engine
Old Sep 23, 2018 | 10:57 AM
Tedster9's Avatar
Tedster9
No. There's only one way the cap should fit, and the OEM type cap should also have a "1" embossed at the terminal. Here is the way it is arranged. Yellow line shows #1 plug wire and terminal. 1 & 6 terminals are basically in line with the two spring clips that secure the cap on the housing. I use the #1 spring clip for a reference to align the rotor when stabbing the distributor.
Old Sep 23, 2018 | 12:50 PM
okie trucker
Tedster, thanks, you clarified a lot of my ????? marks. Now I go to work.
Old Sep 24, 2018 | 08:48 AM
Tedster9's Avatar
Tedster9
You ain't done yet? /jk How'd it go any luck?
Old Sep 24, 2018 | 11:28 AM
okie trucker
Not yet. We had some rain, trucks sitting in yard, so waiting for dirt to dry out. Today's the day. Will let you know.
Old Sep 25, 2018 | 08:35 PM
okie trucker
Got it started just rotated distributor a bit. BUT, it runs with a miss. Never had a miss before. Any ideas on what might cause a miss ?
Old Sep 26, 2018 | 01:10 AM
GreyScar's Avatar
GreyScar
Remove wires one at a time see which one does not change Engine Tone. That will be the Miss, After you double check your wires and Firing order of course.
Old Sep 26, 2018 | 08:38 AM
Tedster9's Avatar
Tedster9
^^ Good plan. This is a points & condenser distributor correct?
Old Sep 26, 2018 | 10:45 AM
okie trucker
Boy I hope it turns out that easy
Old Sep 29, 2018 | 11:37 AM
okie trucker
Well, everything checked out, ok, with firing ang wires being in right place. I'm concerned as to whether or not the distributor was re-installed a tooth or two off. Not sure what would take place. Could that cause a miss ????
Old Sep 29, 2018 | 11:39 AM
okie trucker
Sorry, didn't see this post til now. Yes it is points and condenser
