HPOP Of Choice
Old 09-21-2018, 01:11 PM
Sarge261's Avatar
Sarge261
Sarge261 is offline
HPOP Of Choice
Hey there folks,
Curious as to who has the "go to" HPOP for an early build 03 F550 (12/21/02 build). Long story short the truck came to me in pieces and against my better judgement I agreed to fix the truck. I was going to put a new HPOP in the truck but I decided that I didn't want to "spend" the customers money if it wasn't needed, guess that bit me in the hiney.
Thanks,
Sarge
Old 09-21-2018, 01:53 PM
bismic's Avatar
bismic
bismic is online now
Received 2,494 Likes on 1,731 Posts
Lots of folks are saying good things about the HPOP from CNCFab, but it appears to be out of stock.
https://www.cncfab.us/shop/cnc-fabrication-6-0-hpop-stg1/
The Adrenaline pump is nice, but more $$'s.
I'm not sure I would go with any other choice.
Old 09-21-2018, 02:13 PM
jsm180's Avatar
jsm180
jsm180 is offline
I put a Motorcraft in mine back in the spring. It has a little over 6000 miles now and is doing fine.
Old 09-22-2018, 11:44 PM
riverstroker04's Avatar
riverstroker04
riverstroker04 is offline
I just asked this question as well. I have Warren diesel 155cc injectors in mine so I called them and asked, they said the stock pump would be fine and I couldn't justify 1K bucks for adrenaline hpop! So went with a stock pump.
Old 09-23-2018, 05:59 AM
bismic's Avatar
bismic
IMO this part should last 200K+ miles. Lots of threads on early failures of the stock pump - a lot earlier than 100K miles.
If the wait for the CNCFab pump isn't too long, you probably wouldn't be paying much more than what the stock pump cost. IIRC it was around $800. It has been upgraded to eliminate a housing design flaw (and so has the expensive Adrenaline pump).
If I were looking to buy a used 03 6.0L, and there were two identical trucks with only the HPOP being different, I would easily pay $500 more for one that had an Adrenaline pump. JMHO.
Old 09-23-2018, 07:27 AM
jsm180's Avatar
jsm180
jsm180 is offline
My original lasted 212k miles and was one of the reasons I went oem. There was a warning in the the instructions to prime the pump per instructions, apparently pumps were being returned as faulty when the installer didn't follow instructions.
My luck with the $1000 pump would be it fail and the company go out of business, then I am stuck buying a oem without a core.
Old 09-23-2018, 07:30 AM
TooManyToys.'s Avatar
TooManyToys.
TooManyToys. is offline
Received 2,075 Likes on 1,405 Posts
Did you keep the instructions? It would be interesting to see it.
Old 09-23-2018, 07:32 AM
bismic's Avatar
bismic
Good to know (still don't think I would trust them - too many failed early from the factory which isn't an installation error).
Also Ford states to clean out the HPOP sump (under the oil cooler) and the feed line to the HPOP after an HPOP failure. This could cause some of the issues as well.
Still - (correction) only one report that I know of on Adrenaline failure, so I doubt installation error was the total picture.
Old 09-23-2018, 08:34 AM
jsm180's Avatar
jsm180
jsm180 is offline
No, it went long ago. It was a separate full sheet of paper, highlighted in red and yellow. Definitely gave me the impression that installation error was a major cause of warranty returns.
Old 09-23-2018, 08:46 AM
jsm180's Avatar
jsm180
jsm180 is offline
When mine failed, it would only make 1500 psi @ 84% ipr, it ran fine just low on power, I was 5 miles from home. Everything tested fine but when I pulled the pump it had a tight spot when turning by hand. The replacement looked brand new from the outside, not even a scratch on the housing. I would hope by now they have solved any issues with the pump.
I'm sure the Adrenaline is a great pump, but so is a 2019 6.7, I don't have a need for either one.
Old 09-23-2018, 11:39 AM
bismic's Avatar
bismic
Well said!
Old 09-23-2018, 12:02 PM
jlo84truck's Avatar
jlo84truck
jlo84truck is offline
I replaced mine with a ford reman January and it’s having long crank issues when hot starting. Already replaced the standpipes and j-tube 2003 6.0. I Need to put the air to the Ipr test port and look for more leaks. But the last time I did that I had bubbling sound under the oil filter houseing. I’m not to excited to tear back into my truck again to do the pump a scond time.
Old 09-23-2018, 01:28 PM
jsm180's Avatar
jsm180
jsm180 is offline
I did stand pipes, j tube and the 2 flex hoses to the logs when I did mine. I replaced all the injectors @ 175k. I hope I am done for a while.
Old 09-23-2018, 04:45 PM
navistarnut's Avatar
navistarnut
navistarnut is offline
I justify the extra cost in the fact my time is worth something.
I know the OEM pumps are not ALL bad, or the dealers would not be using them. That said, they are a little more inclined to use a OEM rebuild unless the customer specifies something else
Old 09-24-2018, 12:35 PM
Sarge261's Avatar
Sarge261
Sarge261 is offline
Thanks fellas,
This trucks been a basket case since the beginning. I suspect that the root cause of the original issue was the HPOP failing, it wont even build 15psi, the entire oil system is clean, standpipes have been replaced. I just want this nightmare to be over. Ill call and see what the lead time is on the CNC unit, and check with the customer to see if they want to wait, pop for the adrenaline, or go oem...either way it sucks when you've had the cab off, engine down to the block and you go to fire it up and the thing wont build oil pressure.
I guess that's what I get for saying Ill work on your truck that's 1/2 disassembled! Shame on Me!
Sarge
Quick Reply: HPOP Of Choice
