What leveling kit
Old Sep 21, 2018 | 02:52 PM
Newfordtome's Avatar
Newfordtome
4wd High
Originally Posted by BROWN DOG KTM
35” tires will KILL your 6.2L power & mpg bad.
It’s Hard on O/D with a gas burner.
No disrespect, just be aware.
​​​​​​Why does it kill the mpg and power so much if it is only about an inch bigger than the stock 20 tires?
Old Sep 21, 2018 | 03:41 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM
Originally Posted by willynilly
that does nothing to answer his question. all the springs have the same static height. wire diam is the diference. smaller wire spring sqaushes down more ...
PART of your statement is correct.
My 16 F350 WITH H/D svc frt coil springs sets DEAD LEVEL which is 1.5” higher in front than Standard Coil Springs.
So YES it has Increased ride height : as it plainly states on the dealers computer when you order that option.
Old Sep 21, 2018 | 05:11 PM
willynilly's Avatar
willynilly
16 ? dont they use diferent rear blocks and such. anyways we are in the 17+ section. i havent seen any of these trucks near level, no matter which 3 front springs are used.
Old Sep 21, 2018 | 05:42 PM
Sterling_47ag's Avatar
Sterling_47ag
Exactly 2.5 inches of rack on my stock 17 XLT with 18's & snow plow springs. Has 14k miles now. It was full 3in rake when new.
Old Sep 21, 2018 | 08:07 PM
delorenzomp's Avatar
delorenzomp
So, are there blocks in the rear that can be removed ( or replaced with the correct size ) to bring it down to level with the front? -or-
Since the F350 already comes with a rear sway bar, will ordering one with ONLY the snow plow package provide a level truck ( I am guessing that the camper package affects the rear springs) ??
Old Sep 21, 2018 | 08:17 PM
Sterling_47ag
Blocks can be changed. Mine has 4in block and I do have the camper package with rear sway bar.
Old Sep 21, 2018 | 09:14 PM
BROWN DOG KTM
16 ? ... anyways we are in the 17+ section ....
Exact Same Suspension on both body styles
Old Sep 21, 2018 | 09:19 PM
BROWN DOG KTM
Since the F350 already comes with a rear sway bar ...
All 350’s has the top leaf overload.
I’m pretty sure the Rear “swaybar” only comes with the camper Pckg option.
Old Sep 22, 2018 | 06:37 AM
delorenzomp
Thanks, Sterling_47ag
Old Sep 22, 2018 | 06:39 AM
delorenzomp
Thanjs, Brown Dog KTM, Iwoll double-check what I saw ubder ‘Build and Price’
Old Sep 22, 2018 | 07:15 AM
HST's Avatar
HST
I run F450 7500lb front coils and I dont have a plow. Gave me a firmer ride and the same lift as the previous 1 1/2 keveling coils I was running. These ride really decent considering they are 7500 lb springs.
Old Sep 22, 2018 | 08:00 AM
delorenzomp
I don’t run a snow plow either, I am going for level ( and on the high side as I liked those old ‘hi boys’ from the 70s)...my 2004 F350 crew cab had the snow plow package and sat high and level, I am going for the same effect in 2019.
Old Sep 22, 2018 | 08:06 AM
  #28
HST's Avatar
HST
On these 17+ trucks you almost need a 4" front lift to level. Even with my 1.5 up front I still have a few inches of rake. Keep in mind these trucks get squirly when lifting the front. I have been fighting caster issues for a while now.
Old Sep 22, 2018 | 04:09 PM
  #29
BROWN DOG KTM
Yep you loose the Negative Caster when the radius arms pivots down from longer springs or leveling blocks.
4” lift or more need radius (control) arm brkts dropped to correct this.
Don’t forget an adjustable tracking arm or drop brkt to center the front axle up.
Old Sep 22, 2018 | 04:46 PM
  #30
pgordon888's Avatar
pgordon888
Snow plow prep probably cheapest way to get a more leveled look. I had it on my '19 F350 before I reverse leveled with Kelderman stock ride air suspension kit. Not a low expense option though but very awesome all around.
