Radar Detector Hard Wire
Old Sep 20, 2018 | 01:11 PM
Greg McMahon's Avatar
Greg McMahon
Hey everyone, I just recently got a new Escort Max360C radar detector. I'm using a mirror mount made by blend mount. Very happy with the install. My question to you all is this. Where would you recommend taping into to "key on" power? I would prefer to not use any of the uplifter switch's. Thank you in advance.
Old Sep 20, 2018 | 01:53 PM
desmo21's Avatar
desmo21
Amazon Amazon
Use a volt meter to determine the correct voltage.
Old Sep 20, 2018 | 02:08 PM
oshpunit987's Avatar
oshpunit987
Find a fuse under the dash that only hot with the key on and get a piggy back fuse holder. I think I got mine at Advance. Here's one on ebay: https://www.ebay.com/itm/Big-ACU-Add...8AAOSwu4BV0aoC
I was just curious, how many times has the law caught you while using your radar detector?
Old Sep 20, 2018 | 02:09 PM
fleming23's Avatar
fleming23
Why not use a mirror tap? That is what I did with my Max360 and BlendMount. If you search on here, you'll see which wires to tap.
https://blendmount.com/mirrortap.html
Old Sep 20, 2018 | 02:22 PM
saucemann's Avatar
saucemann
Passenger side kick panel has a bundle of blunt-cut wires. I used Green/Orange wire.
https://www.ford-trucks.com/forums/1...use-panel.html
Old Sep 21, 2018 | 10:30 AM
Greg McMahon
Will this tie it into a uplifter switch? I was looking for constant on when key is on. Thanks
Old Sep 21, 2018 | 10:31 AM
Greg McMahon
Do you have a photo by chance? I do not have a plug on the backside of my mirror.
Old Sep 21, 2018 | 10:57 AM
troverman's Avatar
troverman
One option would be to run a wire all the way to the battery and use an inline fuse. There is also a power stud on the fuse box under the hood you can use. There are "pass through" wires in the kick panel area which end under the hood near the fuse box you can use to get through the fire wall, or you can just run wiring through the grommet on the driver's side behind the e-brake.
Old Sep 21, 2018 | 12:07 PM
roadpilot's Avatar
roadpilot
A quick search found another thread that said THIS thread on the F150 Forums would help you: http://www.f150forum.com/f118/radar-detector-power-mirror-286079
Old Sep 22, 2018 | 10:55 AM
saucemann's Avatar
saucemann
No, that wire is a switched 12V connection - when the truck is on it will come on- no switches
Old Sep 22, 2018 | 01:25 PM
oshpunit987
If you would use that piggy back fuse holder it would come on when the key was turned on and stay on till the key was turned off.
Old Apr 26, 2019 | 05:21 PM
Silverback07's Avatar
Silverback07
Awesome... this was exactly what I was looking for. Thank you!
Old Apr 26, 2019 | 05:31 PM
Lariatdriver's Avatar
Lariatdriver
Buy the long power cord from eBay. Go the Best Buy and have them professionally install the detector usually $50 bucks.
The Work is guaranteed for as long as you own the vehicle. Is it worth it....? you bet!
Old Apr 26, 2019 | 05:32 PM
Section179's Avatar
Section179
I followed this videos’s instructions for the f150:
And used the poor-mans blend mount
https://www.amazon.com/gp/aw/d/B0788XRBTV/ref=ppx_yo_mob_b_track_package_o0_img?ie=UTF8&psc=1 https://www.amazon.com/gp/aw/d/B0788XRBTV/ref=ppx_yo_mob_b_track_package_o0_img?ie=UTF8&psc=1
Old Apr 29, 2019 | 09:46 AM
Texmudder's Avatar
Texmudder
MirrorTap is the way to go. There is even a video for F150s that show you the exact wires to tap into. I have installed two of them now.
troverman
Aug 13, 2018 01:09 PM
Big
Nov 24, 2014 09:20 PM
robroy90
6.7L Power Stroke Diesel
Apr 29, 2011 05:48 PM
uphillbothways
Dec 30, 2007 06:16 PM
tim98
1997 - 2003 F150
May 15, 2003 07:33 PM
