Speedometer cable foam?
Old Sep 19, 2018 | 11:29 AM
jackburtonme's Avatar
jackburtonme
Does anyone have a link to purchase the piece of foam that holds the speedometer cable snuggly where it runs through the firewall? After 220,000 miles, mine has deteriorated, Im pissed....lol
Old Sep 19, 2018 | 02:02 PM
79F150400M's Avatar
79F150400M
I had the same issue on my 79. I found a rubber plug at Lowe's (in the drawers) in the hardware section. I cut a slit in it so the speedo cable would pass through, pressed it into the hole and it worked for many years after that. To answer your question.....Im not sure any of the vendors carry it. Haven't seen one. Take a small piece of foam, wrap it around the cable and stuff it in the hole. (Just an idea).
Old Sep 19, 2018 | 03:39 PM
jackburtonme
ok, I'll rubber plug it or foam it....Thanks
Old Sep 19, 2018 | 03:53 PM
HoustonDave's Avatar
HoustonDave
Can always get a piece of hose the size of the foam, slit it, work it around the speedo cable, then glue the split edges together with super glue. Probably last longer than foam, too.
Old Sep 20, 2018 | 02:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I'm not sure any of the vendors carry it. Haven't seen one.
Originally only furnished with the cable.
FordIowan
Dec 11, 2012 08:46 PM
shark13
Jul 31, 2011 08:50 AM
72sportcustom3906.4l
Jun 20, 2009 05:56 AM
iceman06
Jun 5, 2005 03:41 PM
Nathan
Apr 30, 2001 03:40 PM
