steerin wheel problem
Old Sep 18, 2018 | 07:54 PM
polo68's Avatar
polo68
Hi, I have a problem. This week I replaced the steering shaft on my 2008 ford f150 stx, but I forgot to secure the steering wheel and now its crooked. When I drive straight, the steering wheel is not in the center, does somebody sometimes have this problem.
Old Sep 18, 2018 | 09:07 PM
redfishtd's Avatar
redfishtd
Set your wheels straight and redo it
Undo linkage put steering where you want it lock it down rehook link back up . When I had alignment done my steering wheel was little off . But not too far so I have lived with it .
Old Sep 22, 2018 | 07:58 PM
Bent6's Avatar
Bent6
Dorman shaft did the same thing on my truck. You can adjust the tie rod sleeves. Just be sure adjust them the same number of turns on each side. One side will be made longer and the other will be shorter. This won't change the toe adjustment at all. It will just change the steering wheel position. Or you can pay for an alignment.
Old Sep 23, 2018 | 07:00 PM
polo68's Avatar
polo68
thanks,now is better.
dr_rock
Oct 25, 2018 04:18 PM
Keymaster
Dec 27, 2017 06:38 PM
Davidjoe
Large Truck
Jan 7, 2016 11:31 PM
sum_weirdo
Oct 25, 2011 02:02 PM
MikeGV
Jan 20, 2005 06:10 AM
