NO POWER!
Old Sep 18, 2018 | 11:04 AM
fredb13340's Avatar
fredb13340
Angry NO POWER!
I have a 2004 F250 6.0L - lost power after stepping on peddle. The air cooler pipes on front of engine came apart after I forgot to tighten after replacing a hose. Have not been able to get power since then - will only idle. Can anyone help?
Old Sep 18, 2018 | 12:59 PM
xcrsp440's Avatar
xcrsp440
Are you saying the vehicle starts fine and will get idle smoothly, but when you step on the throttle nothing happens? No rpm change at all as you push on the throttle?
Do you have a tool to look for codes?
Old Sep 18, 2018 | 01:37 PM
fredb13340's Avatar
fredb13340
Starting hard, will idle lower than normal. Once warms up, if I hold my foot on peddle the rpms will slowly come up. Put in drive and loose any rpms it just had -
Old Sep 18, 2018 | 02:19 PM
xcrsp440's Avatar
xcrsp440
You need to get a monitoring device and start looking at numerous outputs. Could be bad FICM, HPOP issues, injectors.
if you have a smartphone, download the Forscan app and get a obd WiFi or Bluetooth adapter that will work with your phone.
lil'ford
Feb 24, 2015 07:10 PM
Galizien
Apr 17, 2006 09:37 PM
mstepchinski
May 21, 2005 10:41 AM
tnmale46
Jan 8, 2003 10:12 PM
