tps problem
Old Jan 7, 2003 | 10:15 PM
tnmale46's Avatar
tnmale46
tps problem
1994 f-150 4x4 5.8 idles at about 2000 rpm and has no power when pulling could it be the tps
Old Jan 7, 2003 | 10:55 PM
standman's Avatar
standman
tps problem
Check your air idle bypass valve.Sounds like it died on you.It is mounted on the bottom right hand side of the throttle body.
Old Jan 8, 2003 | 06:03 PM
steve83's Avatar
steve83
tps problem
Old Jan 8, 2003 | 09:11 PM
steve83's Avatar
steve83
tps problem
The IAC only works at idle, so it wouldn't have any effect on the pulling power. The TPS is a possibility, but so are all the other sensors - have you pulled the codes?
http://www.broncodata.com/tech/codes.htm
Old Jan 8, 2003 | 10:12 PM
tnmale46's Avatar
tnmale46
tps problem
havent pulled codes but checked tps with volt meter return volts were 2.5 book said it should be 1.0 tahnks for the replies
Uncle JimBod
Nov 23, 2022 04:31 PM
merc460
WTB - Parts & other
Apr 26, 2014 06:19 PM
hogan1967
Jan 29, 2011 10:25 AM
kellyscott1
Bronco II
Sep 30, 2003 01:49 PM
